Full Version: RF T212D2 Vs Alpine type X 12 inches
Cinbabe
Okie guyz.........
I heards alot about 1 good sub is better than 2 inferior subs,I prepared to trash out my 4 months old 2x R types and upgrade to one better sub,I have MRD-M1001 to run the new amp.
I got 2 sub in mind i.e RF T2 and TypeX
this is the spex for RF T2
12"
Dual 2 ohm voice coils
1000 RMS / 2000 Peak power handling
304 oz triple stacked motor assembly
4" anodized aluminum voice coil
8 AWG speaker terminals
8.875" depth
2.25 cubic feet enclosure size vented
Cast 2 piece aluminum basket
high excursion thero rubber surround
Mirror image symmetrical spiders
Massive triple stacked magnet assembly
4" anodized voice coil former
Parabolic triangular cone geometry
embedded 12 AWG tinsel leads
Removable concealing ring
Alpine Type X
Power Handling Capacity (Peak): 3000W
Power Handling Capacity (RMS): 1000W
Frequency Response: 23Hz - 200Hz
Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp Cone
Ultra High Excursion Multi-Roll Injection Moulded SantopreneŽ
Mirrored Progressive with Perimeter Venting
Compound Radius Curve
Cast Aluminum Internal Stacking, Vented Leg/Spider Landing with HTP
Extended Dual Flare Pole Vent
High Strength Brass Voice Coil Bobbin
Machined Insert Blocks with Housing, VC Connection Jumper System
Copper Shorting Sleeves with Thermal Coupling Plate.
Now,many of u guys will say why have to be these two but not ID Max,so on and so on.
I just like the look of these 2 sub and the power out put is phenominal,it's just my personal choice that all.
If anyone have come across these 2 sub please put some thought to help me to decide.
for starters, you'll want a dual 4ohm sub (or SVC 2ohm) to provide a 2ohm load for your monobloc. the type-X is dual 4ohm, and the RF T2 is available as dual 4ohm.
i've heard little of the RF Power series subs, and not sure why they aren't more popular. RF have always made great subs, and these look no exception. amazingly large 4" VC, and very good 19mm linear xmax (cone excursion), same as type-X. should prove to be really loud and produce effortless subbass. i would only suggest auditioning before committing.
the type-X is a top performer and quite popular. not the most efficient compared with other around (no idea how it compares with the RF), but will still go louder than required for daily use off your amp, no probs. subbass is meant to be quite accurate and very hard hitting.
is your choice limited to only these 2? plenty of tough competition at this pricepoint. but i'm sure you'd be happy with either for SQ and loud listening. just ensure the RF is a dual 4ohm.
jas
stop this stupidity
this is the plan
single idmax 12 dual 4ohm for the m1000 amp
no type x
no t1 rfs
idmax its been discussed and thats what you are getting
Cinbabe
QUOTE (jas @ Nov 14 2005, 08:31 AM)
stop this stupidity
this is the plan
no type x
no t1 rfs
Hay hay captain monsuer
Shreknos
i got a x runnin off same amp... hits hard hits low hits real accurate, on the ball on standard volume levels and bone breaking while turned up, the T2 costs almost twice wot the x does, mostly due to the fact that its imported from u.s. both will hit hard jus depends which one u prefer. but i couldnt say a bad word bout my x besides that its very power hungry. good luck dude
But in the Car Audio and Electronics review the Rockford T2 finished in 2nd place ahead of the ID MAX..........
I know the ID is popular on here, but the Rockford is an awesome sub.
