The floor is fibreglassed and utilises a slot port. There was no tuning involved i just threw 3 bricks in there to lift the tuning frequency slightly.
Anyway the equipment used was to begin with 1 Soundstream XXX Goliath 6500D and 2 Tarantula T410 subs for a top score of 148.7 the amp was loaded down to 1.2 ohm.
Then we thru the DD 9910 in wired in series than parallel for a 0.5 ohm load. The score went up to 149.7.
Then we strapped the other XXX in onto the DD 9910 and wired each coil in series and wired both subs in series. So total impedance was 2 ohms therefore each amp was operating at about 1 ohm each.
Score 150.6
Then we followed up with the two Tarantula T410 subs and wired the coils in series and then paralleled the subs so each amp was seeing a 0.5 ohm load.
Score 150.2
The difference in price between the two brands of woofers.
DD 9910 dual 0.5 ohm coils - $2199 each
Soundstream T410 dual 1 ohm coil - $699 each
Here are some photos of todays testing.
PS. This is not an attack on any brand just a testing session between the brands that i had available to me.
