alot of talk has gone on about sub tests.
spl x sub vs y sub.
i think at finals we should do some tests in a street "test car". with a solid voltage setup... maybe one of the ss cars or the such may be able to help with this side of things?
i'm happy to supply an atomic ap spl 12" dvc 1 to the tests.
and i'm also happy for anyone else to supply a box if they aren't happy with the one i build.
as for the amps i can supply an amp 3kw able to burp down to the .5 (e audio) and also 2 ohm.
the reason i think to test the subs at different loads is to see the difference when more power is put into the woofer.
any others willing to put their woofers up for the test?
alot of talk goes on about how great different woofers are so now the chance is here to see if your gear can cash in the cheque your mouth has wrote.
please don't fill this thread with crap either..
i am well aware of the factors that will effect this test with the box design and size and the such but for those of us that have thought of this in the past it is impossible to have it perfect and i believe that this would be the most ideal situation.
