Full Version: Eclipse CD8455 HU
BMWTurbo
Hi Guys...
I've been searching and searching and can't find anywhere that actually lists the adjustment of frequencies for this unit.
I need to run :- Sub LPF 50-100, Midbass BPF 50-100 <-> 1500-5000, and Tweeter HPF 1500-5000
I can't find definitive info on whether this unit can do this for.
Can anyone shed some light on this for me?
Ben
BMWTurbo
"PRO MODE- Crossover
Front- 63hz, 80hz,100hz, 125hz, 160hz, 200hz,250hz, 315hz,400hz, 500hz,630hz,800hz, 1khz, 1.25khz, 1.6khz, 2khz, 2.5khz, 3.15khz, 4khz, 5khz, 6.3khz, 8khz, 10khz
REAR- independant from front- same areas of x-over as FRONT
SUB- 63hz, 80hz, 100hz, 125hz, 160hz, 200hz
All 6,12,18, 24db selectable slopes"
Looks like it will do the job...
the_iano
Yep has the exact same tuning capabilities of the model it replaced - 8454
If you get stuck let me know. I know pro mode inside out.
BMWTurbo
QUOTE (ikerr @ Nov 21 2005, 01:55 PM) *
Thanks Ian... I might have to take you up on that offer at some stage smile.gif
I noticed the CD8445 is a long way behind in crossover abilities and it wouldn't in fact run in full 3-way. It appears only to have HP HP LP, which is very limiting. And the exta 3 bands of parametric EQ the 8455 offers is a big bonus also smile.gif
