QUOTE (Big Paul @ Dec 2 2005, 12:16 AM)
i purchased some K+H Spray on undercar deadner, sprayed it in the wheel arches of my old magna, was impressed. Cost around $10-$12 a can.
Will be doing the same to the mirage soon.
Most automotive stores stock it, i got mine from autobarn when they had a big sale on, cost like $8 or $9 i think.
is that a black sticky spray? when it dried up it becomes like kind of rubber, yeh I used it just recently. I sprayed my wheel arches but don't feel much difference, I'd like to spray the door too but its too difficult to reach
thanks for the suggestion
QUOTE (blanketman @ Dec 1 2005, 09:00 PM)
put s/d on the wheel arches
front and back and cover that with sound underlay then with the carpet
because your wheels are in the same cabin space
thats why you will have these problems
s/d ?, is that Sound Deadening? which part should I cover ? and with what material? I wish someone can show me exactly the X-Spot.
anyway you sugesstion is very helpful, I'll try something out
thanks
QUOTE (wald0 @ Dec 2 2005, 03:29 AM)
It's likely tyres are definitely contributing. I can recommend Goodyear Eagle F1 GSD3's. Low noise (no real 'hum' or 'roar'), lasting really well and are nice and grippy in both wet and dry conditions. I think the've won an award or two as well...
Edit: Japanese cars tend to skimp on sound deadening to keep the weight down. Can you find out where the noise is coming from? Is it the wheel wells? Underneath the car? Through the doors? What kind of noise is it - i.e. is it wind noise, road noise (tyre roar), etc.?
My brother has used the bitumen based sound deadener in the wheel wells of his (now sold) Subary Liberty and said it was a noticible improvement. But he had Bridgestone Potenza's on there which are notoriously loud. Perhaps a combination of this and some internal deadener like Dynamat might yeild some decent results?
I used Bridgestone Potenza RE88, don't really know if that the main cause of noise, its a stock tyre from factory.
the noise I heard is defenately road noise because it changes in different road surface, on the smooth surface it will sound like hhhrrrrrrrrr , and on the rough it sounds like grrhhmmmmmmmm, hahaha I don't know how to say how it sounds exactly, but it is defenately road noise
what is a wheel well, and where is it locate, what kind of deadener you using?
thanks a lot
