QUOTE (Ruger3 @ Jan 30 2006, 09:08 AM)
ah thanks for the help fellas this works well for me
its 4 x 12 dvc fusion subs. havent got the amp yet trying to find a single d2 to run it all.
what fusion ones are you using man cause if their encounters 1 amp will be able to power them fine.
but if your using power plants then 1 amp is going to cost you a pretty penny to get cranking 3.6kwrms
as thats what 4 FPW1200 are rated added together the 4 in total total which means you would want an amp that atleast crank over 4kwrms.
but anyway
i would say be smart as you would prob be in SM3-4 with me if your running 4x 12'' subs, unless you go upto SS3-4. go buy two decent amps will work out cheaper then buying one amp big enough to power the 4 subs.
