Full Version: Perspex Supplier?
swtwgn
im after a bit of perspex ad wanted to know if any one could suggest a supplier of some in victoria, ive seen it in bunnings and its damn expensive, anyone else have any suggestions..
check the yellow pages: plastics-products -wholesalers/manufacturers.
in the past i've used my local supplier (ResiPlex, Geelong) for many acrylic/perspex pieces. i usually supply a fullsize template made of thick cardboard for them to work off. they then use their computer-operated CNC router and cut it out.
perspex/acrylic is expensive. a 20~25mm piece around 600x400mm, with hole cut out for sub, is unlikely to cost less than $100~150, cut to size.
if you don't need any holes cut in it, use glass. much tougher and cheaper. silicone it into place.
swtwgn
QUOTE (shiny_car @ Jan 31 2006, 08:37 AM) *
thanks mate, yeah its just to make a window for my amps, im thinking glass is the go, hell of a lot cheaper, and like u said if u dont need to cut a hole in it...
definitely glass then. far greater scratch-resistance, and cheaper. depending upon whether you'll carry gear atop of it, you can go with 5mm toughened glass; this is plenty strong enough and what i use, including putting light luggage and shopping on it, no worries. i have previously used 8mm plain glass, but was advised that 5mm toughened is stronger and lighter and not much more expensive.
