Im trying to make an SQ oriented box here by the way.
Im thinking somewhere around the 50L mark, with the port tuned fairly low, maybe 28 - 30Hz?
Would this be any good in terms of sound quality, and what could I do to improve it?
Im using WinISD to design it (first time using the program). Id kinda prefer to do as much as possible myself... I dont see the point in setting yourself on a learning curve if you get someone else to design it for you
So far it looks like Ive managed to get a fairly smooth response curve from it... Should I try to make it peak slightly anywhere? Currently it dips a little at between 40 and 50Hz, after peaking slightly at just after 30Hz. I listen to a pretty wide variety of music, everything from rock to rap to dance and trance to metal and almost everything in between, if that helps?
So Im basically just looking for advice in terms of whether Im heading in the right direction or not...
Also, what sort of port is most suited to SQ if any? Slot? Round? Something else?
Sorry, one more thing, Im planning on having 2 ports if possible. Im planning to have the sub mounted inverted on top of the box with two ports firing at the back of the car. Would this be reasonable?
Luke
