i'll have to chase up the relevant thiele-small specs - Fs, Qts, Vas - and model them. if you have the specs, post them up; they are required to design a box.
ok, the specs i have are:
*Fs 23Hz
*Qts 0.38
*Vas 98L
it will probably sound a bit better in a 'sealed' box, although ported is ok. if you have enough power on tap (ie: high quality monobloc, 500+WRMS on tap) i would go 'sealed'; this will retain accuracy and loudness, no probs. a weaker amp would benefit from ported cos if the added efficiency, or if you enjoy loooow, phaaat subbass.
*sealed: 1.5cuft
*ported: 2.5cuft tuned to 25Hz (eg: single round 4x18.5" port)
2.0cuft for a ported box is verging on 'too small'; especially if that's the 'gross' internal volume. meaning once you add the sub and new port, the 'nett' internal volume will be less than 2.0cuft, and maybe 1.7~1.8cuft (definitely getting small then for this sub). but 2.0cuft nett tuned to 28Hz will throb hard (eg: single round 4"x18" port).
