Regardless of whether they are here for the long run or not, you can not deny the impact they are having all over the world. In-car computers are huge at the moment because they offer so much more than a normal car stereo. Well actually, that statement is probably a bit far fetched. What I should have said was that Carputer controlled systems are more versatile than the current crop of Car audio systems and to top it all off, they are more cost effective too. Now, that is one hell of a statement and I am sure you are all dying to start the “Great Debate” however I feel these comments are justified given the current shape of the market.
The idea of this rant is not to share my opinions of the current in-car trends but more to give an in-site to the Carputer scene and break down the requirements for a complete system.
The Basics
The idea behind a home PC is generally to stretch the budget as far as possible in order to purchase the fastest CPU, most RAM and best featured Motherboard etc. Does that sounds about right to you? This is where the amateur Carputer builder goes wrong…I know I did
Carputers are generally not based around the powerful products because most modern components are extremely power hungry. A lot of people think that powering a P4 3.0gig computer with a 350watt PSU in their car is no big deal because their 1000watt Mono Block is doing just fine, right?...WRONG!! Sure, it can be done but there are a few things that need to be sorted out before you can throw Dad’s home office PC in your boot while he is away on vacation. Power is a major issue here but I will cover that later on.
Access Your Needs
Before you start buying components you need to work out what it is that you want to achieve. Are you simply after a mass mp3 storage device? If so then how big? Do you want to use GPS? Wireless Networking? Or maybe you want to be able to play the latest version of Underground in a more encouraging environment. Working out the aim of you project BEFORE you start throwing money around will ensure that you get everything right the first time around.
Ok so the aim of my Carputer is to store my entire mp3 collection, play DVD’s, access my wireless network, use GPS whilst using a motorized, in dash display which must be touch screen. Now that I have assessed my needs it is time to choose my components and work within my budget.
Looking at my list of needs above, it is clear as day that I do not need a “Holy Crikey That’s Fast, Batman” Carputer. At most I need a 1Gig CPU with 256-512Mg Ram, 40gig 5400 HD etc. The beauty of using a “not so hot” and “powerless” computer is in fact, EXACTLY THAT!! Slower CPU’s will produce far less heat and require far less power. Believe me when I say that this will be of benefit when I start to talk PSU’s.
Via Make some great Mini-ITX boards that include built in CPU’s which use very little power and they are extremely popular with the Carputer scene. They are commonly sold in 800 MHz-1.3 GHz models so it goes without saying that one of these boards will suit me need perfectly.
Ebay is your friend when you are building a system like this because you can save heaps on second hand parts!
Power To The Masses
Righto then, let’s talk about power…its great stuff isn’t it. Unfortunately we take it granted and it is not until we are in a DC power environment (in a car for example) that we realize how important it is to minimize our power consumption. For example, I am sitting here using my wireless keyboard and mouse, a P2.6 computer and a 42” monitor. I’ve got USB this and Bluetooth that…none of which ever gets turned off. Well, apart from the limited life TV that is. I have all this stuff running without a single thought of power consumption. Geez, I wonder how long it would last in the car
When Powering a Carputer there are two options, Inverters and DC PSU’s. Both of which have their own advantages and disadvantages.
Inverters - are the most commonly know power converters and can be used for powering a range of electronic. There prices can vary greatly based on their output and features. The inverter works by converting the DC power from the battery into AC power to power the PC. The computers power lead plugs into the inverter just like a power point. Whilst Inverters are readily available, cheap, and easy to install, they are prong to induced noise and heat.
DC-DC PSU’s – are by far the best option if you are serious about the well being of your Carputer. These units are designed for the automotive environment and therefore have great features such as battery monitors and startup/shutdown controllers which automatically turn on/off your computer safely.
These PSU’s are slightly more involved to install that the inverters but the way I see it, if you can build a computer then you can install this! Unfortunately, DC-DC PSU’s are more expensive then inverters, especially if you are running a powerful computer however I feel this is justified given the extra features and safety.
Ft you are planning to use a DC-DC power supply then you need to choose your other components wisely, otherwise you many find that you are paying out hundreds in order to power your computer. For example, I will probably need to spend around $150 on an M2ATX PSU to power my proposed system. My P4 2.6 home PC would probably need a DSATX PSU which would cost the most part of $300-$320AU…Ouch!
In order to find out whether your selected PSU can power you computer, simply locate your CPU here and take note of the Max Power Dissipation column. Unfortunately these are no details for my CPU so I’m guessing around 35watt. The PSU I have selected it the M2-ATX which runs a 12v rail at 8Amps. To find out whether the PSU will power the CPU you simply the “Rail Voltage” x “Amps”. So in this case we multiply 12 x 8 = 96watts which will be enough to power everything. You need the power output to exceed the power of the CPU because there are obviously other system components that will require power.
To Be Continued…
