QUOTE (sphell @ Feb 9 2006, 05:11 PM)
As a general guide, you usually add up the fusing on your amps and that's what you run as a power fuse. So if you had two amps with a 25A fuse on each, then you would use a 50A power fuse.
The fuse is just there to protect the wiring, not the amps.
Yeah, I heard of that rule before too. That suits my current setup because my amp has 2 30A fuses.
