Bouncing like you see in movies/film clips can only really be achieved with hydraulics, airbags can do a bit of a bounce (with fast/large valves) but its not quite the same as hydraulics.
Basically the main difference between airbag components is quailty, then its a matter of accessories.
eg, basic setup = control panel, 1 tank, 1 compressor, valves, wiring, lines, airbags might cost $2.5-3.5k
Installation can cost upto $1500, engineering another $500, then its a matter of accessories.
A more expensive system (using mine as an example) is listed below.
2 tanks
4 compressors
1/2 lines + valves
Wireless remote control
Dakota digital auto-levelling kit + wireless remote
4 x airbags
A setup using these things might cost $6-10k, depending if you have connections, are installing it yourself...etc, but it will be a nice reliable system.
As i mentioned before, plan your system before getting one. My original system was all i was going to get, now i have changed my mind and going for 2 tanks, 4 compressors (originally had 1 tank, 2 compressors) and auto-levelling kit. I have to re-do most of my setup now, and have probably paid an extra $500-1000 for parts which are now redundant (current tank, wiring, control panel)
Take a look at www.tubularsuspensionsystems.com or www.airide.com.au for some prices/examples
