QUOTE (IM.10.WR @ Feb 14 2006, 01:02 AM)
ahh i get it.so you pause it, let the battery store up some power, then unleash the fury???
Well the battery isn't "storing up" power while it's paused.
Basically, between burps (which are usually about 1-2 seconds long not 5), you try to achieve the following:
1. Let the amplifiers cool down again
2. Connect a charging device to your batteries so they can recharge
However, you can only achieve no 2. between "runs" - usually a run is a 30 second period in which you set a score. Most competitors will burp once during a run, perhaps twice, one at the start of the period and one at the end.
The intention is that your batteries will have the most charge, and your amplifiers will be as cool as possible, before trying to set your SPL score. After all, as the amplifiers heatup and the batteries start to lose strength, you lose power and thus SPL.
