Hi
Im buying a d2 but i know they havent go the best history. what can be done to tuffen them up? it will be running at 2 ohms daily is this reliable? i have 4dvc 12" subs and plan to run it at 2 ohms for every day im also thinking about getting a second one and wiring each amp for a 4 ohm load. should i maximize the setup to keep heat down.
just also wandering if i change caps or fets or anything is there anything i can do to strengthen them a little.
it will have its own run of 0ga just for it im only running a century stock battery but will be getting an optima real soon.
i do plan on burping this setup i know they can be modded to run super low impedances but im not game enough. i can run it at .5ohm but i dont like mr white smoke.
the subs are fusion power plant 12's
