Full Version: street a
Dark_Stiles
well im going to do it
i am picking up a monoblock tomorow (crap today)
i just wanted to know some of the rules im going to have to folow on sunday
i have looked at the dbdrag website and i cant find any answers
in street a can the car be running during burps (i have a normal batt)
i have a 1990 camry wagon
can i have the back seats flolded down.
also
i am running a jaycar 12" in a 2.553 cube box what the box is aparently tuned to 19-30 hz
what should i be looking at burping it at
is there anyway to test this without actualy having a meter
thanks for your help in advance
DEVINCHY
QUOTE (bmckinlay @ Feb 23 2006, 03:44 PM) *
also
in street classes the engine has to be off and yes you can fold the seats down as long as the seats lock into place and everything is below window line
well i hit good numbers in my camry wagon at 42 hz but yours i'm not sure
hopes this helps
xplod_au
there isbnt really anyway to test without a meter ears are decieving but im sure if u get there early enough on sunday They might let u test it before hand.
ReMiX
play some sweeps if you can and see where it peaks on the meter.
You should only need a couple of runs before the event..
QUOTE (ReMiX @ Feb 24 2006, 03:37 PM) *
At most friendly store events, they'll gladly help you get your best numbers.
Don't be afraid to ask to borrow a CD if necessary. Play the sweep and look at the graph on Termlab, it will give you a 3-4Hz window of which is your loudest frequency.
It may say, for example, that 55Hz was loudest. Try anything from 53-57Hz in your next runs to see which works best.
Also, tuning your head unit's volume all the way up isn't always loudest. If it goes to 35, start around 26 and edge your way up to achieve the maximum output.
And, above all. HAVE FUN!!
Dark_Stiles
can you play music at all as i have a track that hits the loudest note in the car
is there anyway to use temlab to find out what this note is
fish-man
QUOTE (bmckinlay @ Feb 26 2006, 12:32 AM) *
You can if you want, but what you will find that what "sounds" loud and what actually measures loud are two totally things, tones are the only what to get the most out of a system (for spl).
If you can get time on a term-lab it's easy to find out what frequency your car is loudest. Run a sweep first, the meter will give you the answer straight away. See on the bottom left graph? Shows the loudest point was around 62hz. I normally test 3 or 4 either way, once you find the peak (never know)
CAA guys constantly hold "test & tune" days, find out if someone is holding one near you, go along have a go. Testing makes and incredible difference.
Michae1
In your first qualifing run its always best to play a sweep, as even the slightest change in conditions like weather, can change your peak by 1 or 2 hz either way.
Dark_Stiles
Just a fill in guys
i ran today hit 136.6 in qualifying round and 136.1 in round one got knocked out by team loud and clear.
Verry happy i didnt think i would get over 120
DB JAY
QUOTE (bmckinlay @ Feb 26 2006, 10:38 AM) *
Just a fill in guys
So will you be running again? doing a few improvments untill then?
Michae1
well done mate, its amazing how many people go to these comps thinking, it'll only do X db, then are genuinely surprised and happy to hit a 136db.
If only it stayed that way (being so easy to please with scores)
Dark_Stiles
yah i alredy want more i want to push this one box to at least 140
i had hit a wall in power levels
my amp just wasnt geting enuf curent
so time for a new bat
funny thing is that i hate this sub for lisning to music (more to do with box tuning) now i want to 10s for everyday lisning and maby 2 12's for spl
BlackIce
hahaha you did good with that setup mate, you also convinced someone to buy the same sub as you wink.gif (they'd been contemplating it)
Dark_Stiles
thanks mate
now just to wait till autosalon
mark_sudakov
thats an awesome score
Pyroay
QUOTE (Db Barina @ Feb 26 2006, 10:40 PM) *
Well done It is a lot of fun competing regardless of if you win, trying to better your own personal best.
With a bit of tuning a maybe a more powerful amp you should easily get 140's and that sort of score will stand you in pretty good stead for a lot of comps.
mark_sudakov
how much rms did u feed the sub?
Dark_Stiles
sub was geting 700ws
but the bat in my car is crap
so i think that was holding it back
but im eyeing of the new jaycar amps
ow and to answer everyons questions
I had the time of my life
im bitten by the bug
DEVINCHY
good to see that you had fun but dont put the wagon down on its size as i told you at dorans it is able to do the numbers with the right gear
see ya at autosalon
Scuby_snax84
QUOTE (bmckinlay @ Mar 2 2006, 01:22 PM) *
It only gets worse at 140....
That bug bites harder!
