QUOTE (rawan05 @ Mar 1 2006, 11:48 PM)
ok so i heard a few i list them down
went to alberts myaree and heard:
mb quart discus and premium , were good but not great, guy didnt turn them up or anything on my cd, complain bout mp3 and all that but didnt really find them great, he recommended the reference line the most but didnt have a set on displya
alpine r, x and dddlinear ones. r were ok, x i like but not that great and linear ones were good, again guy didnt turn them up and didnt suggest for me to go with any of them
i didnt like the fact that they didnt let me audition the speakers reall good with volume up on my cd, at the moment im considering type x for price and quality
went to westside car audio and heard:
focal 165k2p and 165v2s, both were pretty great, v2s was better cause they pumped more but tweeters were harsher, guy said that k2p were better but cause runnign of deck, they need lots of power to sound good, he wouldnt let me audition the x types, kept avoiding them and recomended focals a lot
went to tecknik car audio
guy told me that morels are really good, he dont have a set for 2 weeks, they stopped geting rainbows, but i cant audition with them so thats a dillema
ok prices
mb quart premium pce 216-$799
mb reference rce 216-$579
mb discus dse 216-$399
type x spx-177r-round $500
type r-$399
focal 165 v2s-$399
focal 165 k2p-$789
really considerin type x at the moment or linear one($799), type x werent that great but linear ones was good. also considerin focals. v2s were pretty nice other than harsh tweeter. k2p would be good if i had amp at moment
i still wanna listen to few morw speciall boston pro 60 so undecided at the moment. whats the experiance with type x here, who has them and how r they? any recomendations on the other choices
If money is going to be a factor, the Alpines probably will offer the best compromise,
since they will run well off cheaper Japanese amps or any amp for that matter.
the Focal K2P is going to be alot pickier speaker, in terms of it's input, a Quality USA hand made amp is probably best, with at least 100W if not 200W a side, Damping factor of at least 500. Generally depending on where you run the TN52, you will need to tone it down, I run up on the dash at -4DB luckily if you use the focal X/Over it has 1-7db drop in 1db increments, so that won't be a issue.. The other issue is if there is even the slightest imperfection in your install, these speakers will show it in the sound where other speakers probably wouldn't. Basically, these are audiophile speakers, they need to be backed up by Audiophile quality running gear.
the TN47 on the V2's I Believe is harder to work with, it will work better off a "quality" US based amp. But if you run it on a head unit or on a Japanese amp you'd probably be quite disapointed.
Alpine on Alpine I found works very very well, because it's designed to work together. And when you do put a Alpine speaker on a Alpine amp, They represent great Value versus performance.
but mix Alpine with something else, and results tend to vary and (talking about everything BUT the decks) and usually for the worst. I'm quite a fan of there decks, but mainly because they are value for money,
I don't run one myself though.
I imagine the DD Linears would need a amp to run properly, even the Type X for that matter.
It's up to you, the Focals are not really that great for R&B, Rap type music, but they can be fantastically detailed and clear, I found the K2P midbass to be able to take massive amount of abuse without any hint of distortion, but it's not a "deep bass" "massive hitting" sounding midrange, If your planning to run without subs, give them a miss. if your running with subs, it shouldn't really matter the K2p's produce plenty of midbass to blend the bass freq's across from the sub when setup properly. It's just up to you if you like revealing detailed sound, or something more hard hitting but less accurate.
I've run MB quartz with good luck, but mainly only the base models.
they work pretty decent, with a nice crossover even the base models can sound pretty dam decent!
it's the lack of a decent Crossover that makes most mid range speakers sound junky.
I run K2p's but in a active arrangement, in a ute.
be happy to let you have a audition if you wanted also.
might be worth it too hook up with both me and Doug at the same time, so we can all have a listen to them being setup both Active and Passive.
Juls
