QUOTE (bob^ @ May 19 2006, 12:19 PM)
I must ask. What happens to your wheel alignment with regards to constatly altering the suspension height??
Is it one of them things that you set at a certain height, then try keep it at that height for the most of it? Because I can see camber in some cars becomming a problem.
The alignment does change, but its not really noticeable. I've got 19's as well as bags, so i find that more often then not the car will follow the groves in the road rather then get off track due to alignment.
My car (for daily driving) is normally around the same ride hieght. Obviously there is probably a few MM-CM difference each time i get the car to ride height, but i have a live rear axle, so camber really isnt a problem for me. If i had IRS then im sure it would be!
The only problem i have with live axle is that when i lower/raise the car, the panhard bar goes with it, and kicks the diff to the left/right, which means ive im driving 4WD height, then the driveshaft/tailshaft isnt 100% straight. I've had no problems so far, but im assuming that tailshaft/driveshaft lifetime will be shortened!
I'm currently saving for autolevelling, which should obviously increase my chances of getting the same height each time
