Full Version: OMGZ2!
Michae1
Z2 Thread from Soundpressure.com
12.5 volt 60Hz "one 12 volt 100Ah battery"
DD Z1
2279w/max @ 4.6 ohm
3405w/max @ 2.3 ohm
4188w/max @ 1.15 ohm
DD Z2
2045w/max @ 4.6 ohm
3260w/max @ 2.3 ohm
na @ 1.15 ohm The amp is going in protect, not enough power in the battery.
DD Z2 @ 17.5volt 60Hz "2 x 16 volt turbo start battery"
3962w/max @ 4.6 ohm
6503w/max @ 2.3 ohm
7947w/max @ 1.15 ohm
So the Z1 remains the stronger 12v amp, but for SS above bring on the Z2.
2LOUD2OLD
what about figures for the Z1 at 17.5 V??
impressive none the less
brady123
Linky in first post is wrong dude.
Michae1
dammit, it worked before.
fix it later.
Z1 on 16v+ = bad, hence no high voltage results.
brady123
Fixed'd'd:
http://bbs.soundpressure.com/cgi-bin/ultim...c;f=34;t=001432
The Z1 uses 300V FETs, which limits the safe input voltage to 15.5V.
The Z2 uses 400V FETs, allowing for 18V input.
The 300V FETs are faster, giving better efficiency on 12V, hence the Z1 is the killer 12V amp.
That said, I can't wait to strap eight Z2s onto 2 9918Zs in our Extreme Civic. smile.gif
gros16
can we see any log or pics of install for teh civic
QUOTE (gros16 @ Mar 2 2006, 07:53 PM) *
It was featured in the Dec '05 "Car Stereo Australia" magazine.
Drop me an email, I'll send the article to you.
Stooge007
that's some serious grunt!
- Stooge007 out
Michae1
ReMiX
bigger pic?
Michae1
try this
http://forum.soundpressure.com/showthread.php?t=298
and the thread from over at Soundpressure.com
SSS_Hoon
how much are they worth out here in aus land.
SSS_Hoon
SS1 $599
Z1 $2399
Z2 $3999
~Spyne~
phil, what are the specs on the ss1?
QUOTE (~Spyne~ @ Apr 5 2006, 08:32 AM) *
It's tiny, only 15x22cm and rated at 1x600Wrms into 1 ohm (It's been independantly tested to far exceed it's power ratings!)
Michae1
From Soundpressure.com
What can you get from a tiny 155 x 50 x 270 mm amplifier.
Here comes the result from our benchtest performed by Peter. T. (alias Viking Boy)
a) First we used an old standard 12V car battery.
4,6 ohm 354,8 watt
2,3 ohm 566,6 watt
1,15ohm 761,8 watt
We did this test just to show what a regular customer should get as a minimum by using the existing stock battery.
__________________________________________
b) Then we wanted to have some more fun, so we took 14,4 solid input voltage, like a good after market battery, and with the engine running.
4,6 ohm 490,5 watt
2,3 ohm 777,9 watt
1,15ohm 1 029 watt
Wow, thats a lot of power coming out from this little sucker.
Remember, its also bridgeable so you can really get some serious power out from the SS-1 amp.
Here's the SS1:
SPL_Lancer
QUOTE(gros16 @ Mar 2 2006, 07:53 PM)
It's the loudest ever certified car in Aust. 164.4 from one amp!
Can you email the article to me as well phill.
