hi people
i got a 12"MTX sub in a custom made box eg carpeted and not home made and a amp 2X200,1X400wat to run it
all this is brand new
i wanted 2 put it in a car but i couldnt now im sellin it
the sub is $300
the amp is $140
specs 4 amp r
output power max 200x2 channel
out put power (bridged max) 400x1 channel
low pass filter – 40Hz to 1.50 Hz
high power filter – 80Hz – 1.2Hz
Frequency response – 5Hz to 50kHz
Signal to noise ratio - >95dB
Stereo Separation - >60dB
Input sensetivity – 200mV to 2V
Input impededance – 10Kohm
Fuse rating –15A
Overload, thermal and short circuit protection
Inbuilt crossovers
Bridgeable and tri-mode
2 channel
features
class “AB” technology MOSFET PWM power supply
bridgeable and tri-mode operation
continuously variable 12dB/octave High power crossover
continuously variable 12dB/octave low power crossover
enhanced bass boost 0dB/+6dB/+12dB @50Hz
gold plated RCA, power & speaker terminals
soft start and muting
overload, thermal & short circuit Protection
Blue Bar LED power and Protection indicator
Stable into 2 ohms
Adjustable input gain control
PM me if u want
thanx guys
{edit - please read forum guidelines}
[ April 12, 2003, 12:15: Message edited by: Bodyjar ]
