Cinbabe
Mar 16 2006, 02:51 PM
A must for comp system,it will clear up all the wiring connection,in detail please search on phoenix gold web site.
The TDD5 also includes a revolutionary turn on and off delay system to eliminate turn on/off noises. The six delayed remote outputs are
used to turn the system’s amplifiers on and off. These six output’s can delay an amplifier from turning on for up to 8 seconds . It is ideal that the amplifier should always turn on last. This is because if equipment (equalizers, processors , crossovers , navigation systems , etc.) up stream from the amplifier has a turn on noise, the amplifier will not pass the noise to the speakers if the amplifier has not turned on yet. If the amplifier is off it can’t pass any signal (i.e. turn on noises) from up stream components to the speakers . However, if the amplifier itself is the cause of the turn on-off noise there is little you can do to stop the turn on-off noise except for using a different amplifier.
The delayed outputs are also used to keep noisy components on for a longer period o f time. This allows the amplifier to shut off first, then the other components can turn off. If the equipment up stream has a turn off noise that is sent down stream to the amplifier it won’t pass the turn off noise to the speaker, because the amplifier has already turned off.
Amplifiers should TURN ON LAST and TURN OFF FIRST to eliminate turn on/off noise problems .
asking price for 300 aud
Cinbabe
Mar 17 2006, 02:08 PM
Any offer guyz????Someone got to need this
Damo95
Mar 18 2006, 08:23 AM
Tell ya what..
awesome piece of gear here guys.. i have one in my install, and i love it.. slight correction, there are only 4 remote outputs... but each can have up to 5 amps apparently..
good price too, considering you cant get them here any more..
Cinbabe
Mar 19 2006, 12:05 AM
QUOTE (Damo95 @ Mar 18 2006, 09:23 AM)
Tell ya what..
Thanks Damo.
For some reason,not many people known or use this unit.It look quite nice with all the colours light as well.
Tiger
Mar 19 2006, 02:05 PM
nope... you'll be suprised...
IMO, its well worth the money.. but ah well..
[EDIT]Oops.. Damo here on Tiger's comp.. [/EDIT]
Pyroay
Mar 31 2006, 06:47 AM
Where is this stuff when i'm looking for it.... Dammm.
looks good.
Cinbabe
Mar 31 2006, 01:07 PM
QUOTE (Pyroay @ Mar 31 2006, 06:47 AM)
looks good.
Final bump
_Anthony_
Mar 31 2006, 02:11 PM
What are the physical size of this?
Cinbabe
Mar 31 2006, 03:01 PM
QUOTE (The Tick @ Mar 31 2006, 02:11 PM)
Thank you for ur enquiry . External dimensions: 15" * 10" * 7",
Hope it help
Cinbabe
Apr 8 2006, 05:16 PM
QUOTE (Cinbabe @ Mar 31 2006, 03:01 PM)
Hope it help
Open for offer anyone
Hello Cinbabe.
I am interested but I am looking at something very similar from the McIntosh camp at the moment in the US and it can do 10 outputs for a little less money... I'll PM you chief...
Damo95
Jun 9 2007, 08:07 PM
yes it did..
went not long after the last post.. think it can be closed now..
