QUOTE (Ruger3 @ Mar 30 2006, 12:36 PM)
Juls have you got pics or a build up thread? i was considering this and am interested on how you did it. it takes a lot of guts to cut up a door trim on a new car.
i went to doran today and bought the digital designs component set mainly because the power it can take and the build quality of it is top notch
i was hesitant with the peerless i rang up wes and they wanted $156 each for the peerless drivers but my main problem was to be powering them. i really dont have room in my install to fit another amp (got more than you can count on one hand already) the dd's i like the sound of them and for the price i am impressed. the tweeter is quite harsh with the dd's but they are only acting as ambients and my morel tweeters do all the main tweeting.
also a problem i get is that when playing loud the side you are closest too sounds much louder than the opposite side (driver seat - right hand side very dominant over left) any tips on tuning it in any way or speaker placement to correct this? my tuning options are limited the headunit has a 3 band parametic eq (kenwood kdc7529) and im using a digital kenwood 3 way crossover (low pass, band pass, high pass).
I'll try get some pics later today.
in regards to the speaker sounding too close to you,
are you high mounting the tweeter up in the factory premium tweeter locations?
these are equal distance as the mids from your seated position so they are optimum.
I'd also suggest getting a head unit with Time alignment, this will fix alot of the problem,
although you won't eliminate it.
There isn't much you can do in regards to angles ect on the woofer in the BA. Not without serious hacking.
the way I took the Grills off the door, I can glue/screw them back on later. when I sell the car, the whole orginal stereo is still in tact ready to reinstall, well the only thing I removed was the speakers. I left the stock connections ect in place. and ran new wires.
if you pop your door skin off you can see immediately what i'm talking about, how easy it is just to remove the grill part, the door skin still has some plastic there holding the whole skin together, you put wood either side of it.
Juls
