Kramy
Apr 3 2006, 07:46 PM
i am having troble with my download speed when downloading from websites, i have azerus running and its fine , it will download at 150k but when trying to download a file from a web site it comes down around 4.9k. Do i need to forward some more ports or does windows suck.
I have two computers on the network and it is the same for both of them,
Any help would be appreciated.
Ole'
Apr 3 2006, 11:32 PM
mine was doing this
I ended up logging into my adsl modem and teling it to do a manual restart, worked fine after that.
Kramy
Apr 4 2006, 06:14 AM
ok thanks i will give that a try.
Midol
Apr 4 2006, 11:42 AM
Some websites only let you download that fast.
Kramy
Apr 4 2006, 08:16 PM
i have a friend that cab get speeds upto 350 - 400 from this site
Midol
Apr 5 2006, 12:41 AM
Ohhh, your not running azerus at the same time are you?
Kramy
Apr 5 2006, 06:01 PM
no im not using azerus at the same time
Midol
Apr 5 2006, 10:52 PM
Then I do believe I am of no futher help.
But try doing what Ole` said and then try random stuff like turning the windows firewall off, it slows my speeds down heaps.
Could forward more ports but I've never had to forward a single port with my router so I wouldn't have a clue which ports to forward.
Kramy
Apr 6 2006, 09:52 AM
tried restarting the modem but didnt help, any other things that i could try.
Midol
Apr 6 2006, 04:22 PM
Are you using a proxy? Anything special? Turn anti virus and firewalls off see if it makes a difference, clear cookies and stuff? (I am throwing out random suggestions which may or may not have an effect)
Kramy
Apr 7 2006, 05:56 PM
i think i fixed not sure what i did
Courtancer
Apr 10 2006, 10:04 AM
QUOTE (Kramy @ Apr 3 2006, 09:46 AM)
How do you have it running that fast? The best I can get it 50k. Occasionally I get faster speeds on a web page but the max is usually about 50.
I've got a 1.5 connection and I always assumed it should go faster than 50. I've got a D-Link DSL-200 USB modem.
Anyone got some ideas for this problem?
Midol
Apr 10 2006, 06:09 PM
Servers are slow.
File sharing programs people limit their upload speeds.
Kramy
Apr 11 2006, 09:30 PM
all fixed now i have no idea what happened, but its all good
Sigmeister
Apr 12 2006, 07:57 PM
QUOTE (Courtancer @ Apr 10 2006, 09:34 AM)
1.5 speeds should download at a touch over 150Kb\s, you should be able to get this downloading directly from your ISP. Try running a speed test as well.
50 sounds like 512 speeds. Sure you're on the right plan?
Courtancer
Apr 15 2006, 05:12 PM
Yep, even when it connects it says "Connected at 1.5".
mad_bison
Apr 21 2006, 10:49 PM
it can connect at 1.5 but if you're only on a 512k plan then that's the max you can get down your line. with a bit of tweaking, you can get your max download from 50kb to about 65kb.
mad89
May 16 2006, 01:44 PM
mad_bison id like ur help again... haha
i have a 512/128 connection... how can i maximise its speed?
thanks mate...
- mad89
bearey
May 16 2006, 03:50 PM
QUOTE (mad89 @ May 16 2006, 01:44 PM)
thanks mate...
- mad89
yes' i 'd like to know too
, i too have same speed connection
Sigmeister
May 16 2006, 05:24 PM
What speed are you currently getting?
The MAX you'll ever get is 64KB per second
512b\sec \ 8 = 64KB per second. So if you are getting that or close to you're doing well.
I used to get about 61KB (55 down - 6 up) on 512\128.
mad_bison
May 16 2006, 06:06 PM
QUOTE (Sigmeister @ May 16 2006, 05:24 PM)
not entirely true.
my parents have a 512/128 plan that i use when i go home on weekends. (to download torrents etc)
i can get 62.5kb down solid, and 16kb up max(about 13solid).
that's 78.5kb on a 512kbline...
like i said..you can do a bit of tweaking..
it can depend what you're running, and how it's configured.
anything from the provider themselves, to your max tcp connections, mtu size, outgoing/incoming connection limit for the program itself etc.
EDIt; here's a few speed tests...
http://www.dslreports.com/stesthttp://www.freecodemomma.com/speedtestdsl.phphttp://www.the-search-engine-optimizer.com...-speed-test.htmhttp://web.tampabay.rr.com/giis/there's some simple tweak programs i can direct you too..and some not so simple tips that involve some registry editing if you want more info.
bearey
May 17 2006, 10:04 AM
i dont mind editing my registry manually, but if theres a program that can tweak or for me i'd rather go that option for simplicity
