QUOTE (icefusion @ Apr 3 2006, 10:04 AM)
i had a problem with my last sound competition, my sound system topped out at 130db (previous score was 141) and then blew the 3 fuses on my amp, twice.
Check your amp settings.. adjust the gains properly etc. Does it still play music fine ? I assume it does.
i have worked it out to be one of my subs, i put my multi meter across the terminals and if i press the cone in and out a little it cuts in and out, is there any way i could fix this or is it goodbye to my sub.
Pushing the cone in and out changes the elctro-mechanical properties of the coil.. dont push the cone while the DMM is connected because the meters reading will jump all over the place and give you strange results like you noted.
The coils should show within 0.3ohm of their rating (so a good 4ohm coil shows between 4.3 & 3.7ohm on a DMM).
When you *gently* push on the dust cap, does it make a scraping noise ? If so, then it has dropped a coil and needs replacing.
i had it running in the same box as one of my others if this makes any difference, and my other 2 are in separate boxes, 4 x 12 inch in total, the subwoofers are kenwood excelon, model no. kfc-xw1205db, any help would be appreciated
Running in common chambers doesnt make any diference.. and if the woofer is cooked, there's no point getting it reconed. Those Kenwood's are most likely cheaper to buy new than recone.
