Full Version: how to mount amp rack in falcon
gros16
ok pic say it all i wnat simple amp rack 2 attach to amp sto what is teh best easyest way to set it up this way. Oh and i got small 50mm areo port is it fit 2 run 2 lots of power cables as well as speakercable sthru teh same port as well as rca's?
Alex - Formerly Rbimdxe
uh.. what? can you please re-type your post with correct spelling and grammar? E.G; what the hell is an "amp sto"?????
gros16
need amp rack. whats is best way to attach it. look at pic this is what i mean.
also would it be worth drilling 12cm hole sin back of amp racking so i cna out 12cm fans to cool amps from the bottom?
Dogo
i wouldnt bother with fans from the back as long as the hot air can come out the front/top.
the usual methods would do - either find and bolt to existing holes in the boot walls, drill some of ur own, or liquid-nails some wood blocks to the walls of the boot and screw into them
sk8rpnk
LOL. why would you want to cool your amp from the bottom?
gros16
more air the better there is also soem small vent house in teh bottom and im worried teh amp is going to over heat. i fi cna cool any part of teh amp it will dar more heat in reurn i can cool.
due to teh bus bar i cant get rally colse to teh wall but ive stacked about 6 pieces off off cust of mdf jsut stacking them up so all should be good now.
taht reminds me i ahve to send off ya busbar blackice sorry
Michae1
Dude, do us all a favour, LEARN HOW TO TYPE/SPELL!!
You type so much jibberish that I'm sure alot of people don't even bother reading your posts, as they have to read it over and over just to work out what the hell you are saying.
bob
slow down...think before you type...
gros16
yea i know im bad. Ill have to get my firefox plugin again the spell checker
Michae1
No, like bob^ said, just slow down and actually think before you type, then try proof reading it BEFORE you post it.
It's not as though you are spelling big words wrong, you are getting the basics wrong.
TUFFTR
i made mine in an up-side-down Seven Shape
drilled a hole in the car, and drilled a hole in bottom bit (imagine a 7 upside down you'll know what i mean) and bolted the mofo together.
doesnt move an inch,
