Full Version: Question about fibreglassing?
vpbaby
Hey i dont really know anything about fibreglassing, can any one tell me if you can fibreglass on top of wood and over plastic?
Can someone also show me a step by step guide on how to fibreglass?
Thanks alot, JL
mosoto
QUOTE (vpbaby @ Apr 11 2006, 06:45 PM) *
Thanks alot, JL
search is your friend http://www.caraudioaustralia.com/forums/in...3&hl=Fibreglass
or
http://www.caraudioaustralia.com/forums/in...e=%2BFibreglass
vpbaby
thanks,
So i put fleece over the wood and fibreglass on top of that?
pretty much. you can get creative, using sculpting foam for complex shapes.
also, fibreglass resin LOVES mdf. Its easy as to mount a sub to a mdf coutout, and just glass straight onto the mdf cutout. It'll be very secure.
daBOODA
Just make sure you buy a decent respirator mask (I think that's what they're called) for when you're applying resin and cutting/sanding hardened fibreglass. Don't just use a paper mouth/nose mask, a respirator will protect you much much more.
raptor22785
another question guys, if i need to make a base out of fibreglass due to complex curve, what is the best way to mount mdf off cuts to position speaker ring? like you would use wood glue between mdf base and mdf off cuts, would you use resin or something else?
Ruger3
hot glue gun and dowel (skinny wooden cylinder like the thickness of a pencil.) position wherever you want the ring and measure the length to the base. cut the dowel the appropriate length and hot glue it to the base and to the ring. it should hold the ring up in the air wherever you want it. stretch the material over it when your finished and glue it to the base and start glassing
