Samson
Apr 15 2006, 11:32 AM
Hi, Im looking to compete in some SPL Comps.
I have:
Mitsubishi Fto 96 coupe. 80A Alt
2x Audiobahn Immortal Subs (2000WRMS ea. QVC)
1x Audiobahn A4KDN Amplifier (4000WRMS @ 1OHM)
custom box (2.4 CF per sub with 4x ports from manf. specs)
Looking to buy:
3x 100AH Deep Cycle Batteries
I want to connect it all using 0G wire and re-wire the alt and grounds with 0g too.
Please tell me if im missing something...
Dark_Stiles
Apr 15 2006, 03:21 PM
QUOTE (Samson @ Apr 15 2006, 11:32 AM)
I have:
Looking to buy:
First you need to know what class you are going to run in.
and also 100 AH bats arnt verry big.
APS
Apr 15 2006, 03:25 PM
100AH batteries are not big? Hell i run a 90 AH for two XXX amps strapped.
Stone
Apr 15 2006, 04:07 PM
Yeah, 100AH is big... I think you might be confused with CCA. 100CCA is small. My Optima Yellow Top is only 55AH.
Samson
Apr 15 2006, 05:02 PM
I dont know which class is what? its a fairly basic setup. trying to keep it simple. i know a lot about electronics but not much about BIG sound systems like this.... The amp is just getting fixed. Aparently it wasnt getting enough power from the 600cca oddesy. What class should i run in? is it street B i think?
BlackIce
Apr 15 2006, 07:17 PM
Apr 15 2006, 08:34 PM
You can only run a single battery in Street B, keep that in mind.
Dark_Stiles
Apr 17 2006, 12:03 AM
My bad i was thinking about CCA
YES 100 AH is a big bat
Samson
Apr 18 2006, 11:01 AM
OKay, i've just gone to see gold coast car sound. they can get me a 270AH / 2000CCA battery. weighing in at 97 KG and is $699.... i think that price sounds good. i would much prefer to just get one battery to keep in Street B... opinions?
ripped
Apr 18 2006, 11:11 AM
to be compliant in street class your battery must fit under the bonnet. I don't think your 97kg battery will fit
if you like batteries as much as me, just go SS. once you use a whole heap of batteries you never want to go back to street class...
Apr 18 2006, 04:39 PM
The volume the battery displaces is the key for Street classes, see www.termpro.com for all the rules.
Michae1
Apr 18 2006, 09:52 PM
Battery can not be any bigger than 800sq" and must be of a 12v/14v variety.
Must also be mounted in the "general" factory area, read anywhere under the bonnet, even if it means moving (or removing
) bits and pieces.
Samson
Apr 21 2006, 09:28 AM
Okay... so has anyone got any suggestions? ie.... what would you do if you had these subs and amp?
Michae1
Apr 21 2006, 05:09 PM
You dont want to be competing with 3 batteries, you will be put into the SS classes if you do, just get one really good one.
buy one of these 3 batteries, in no particular order.
Optima D31
Oddessey 2150
Kinetik HC2400
xplod_au
Apr 21 2006, 05:29 PM
my advise is to read up on the rules for each class and pick which class you are wanting to run in for sure and build your car to suit that class.
as for gear it sounds like ya have it set there and got gear thats good enough for high numbers.
what i would do if i had those subs and amp build a SS1-2 NW or SM1-2 set-up.
but anyway good luck with it and look forward to seeing its numbers someday
Samson
Apr 24 2006, 09:13 AM
just looking around those batteries are too big i think (the 800 ci rule). but i read on a forums in the US that the Kinetik HC2400 was small enough?. if this lets me compete in Street B then i will definately get it. Street B is what I'm aiming for.how long would that battery last? The reason for wanting to be in Street B is that i want to actually WIN comps. and obviously the lowest category i can get into the better. I would love to crack 150. I am currently talking with Hamish from Gold Coast Car Sound at bundal. He has been very helpful so i will go see them this afternoon and see wether he can help me out a bit.Is there any other rules that anyone thinks i might be up against with my install?
Samson
Apr 24 2006, 09:44 AM
BTW: I have just finished installing some sound deadner. makes a hell of a difference. Did outter and inner shell of doors and rear quarter panels and rear pacel shelf. will this make a difference to my SPL? It has made my front pioneers sound 10x better. and the doors have a luxurious thud when i shut them now. i did that much for $60. I was thinking it would be worth spending $120 and getting another 2x boxes and doing the boot roof and floor. but will it make a difference?
Also, where can i get kinetik in AUS?
Apr 24 2006, 09:54 AM
What sort of car?
pingpong
Apr 24 2006, 12:12 PM
QUOTE (DD Phil @ Apr 23 2006, 11:54 PM)
What sort of car?
He mentioned its a 96 FTO at the top
Samson
Apr 24 2006, 12:19 PM
lol.... I know its not a hatchback but it does have a small cabin area.
