Ok, it's down to 178.7lt,
Make the port 404mm high, 80mm wide and 355mm deep/long.
So you'll need to cut a hole in the front of the box 80x404 and cut to pieces for the ports 404x337mm which fix in behind.
QUOTE (reefhog @ Apr 20 2006, 08:14 AM)
It would be better if you design the box to be the right size to suit the subs.
There is no one "perfect" sized box.
Ported boxes are very flexible, you can build them to suit your needs and music tastes.
