Full Version: need help with EQ PHD5
gros16
this is what i posted on tempro
this moring i was driving alone no ware near at 100% about 50% when my amp refuse dto work it did put some sort of sound thru the sub every 10 seconds so i turned it of then turne dit back on to see what had happened same prop. then at work i went and looked at amp all seemed fine. when i started the car it worked so i was happy.
on the way home i got prolly 100m then it stoped all together the amp is making a horrible high pitched noise and now the Thermal LED is on (red) it has cooled down i have disconnected the power and reconnected it but still same prop what does this sound like to u?
any idea or any one that knows any thing about EQ amps
SSS_Hoon
sounds like a short somewhere.
check the pwoer wires are not touching eachother and that its earthed correctly, and that the speaker wires arent touching.
SSS_Hoon
gros16
ive taken it out and hooke dit up 2 a spare battery. with no load on it still does the same thing. would it needa load as one of teh speaker cablers was loose in the car. so it might of ran with no load. ive opened it up nothing is burned
BlackIce
The simple answer is.. its an Earthquake. PM me and I can give you the details for the Aussie importer (and who to talk to).
