QUOTE (tis_paul @ May 19 2006, 07:15 AM)
The IDMAX definately sounds the way to go, heard too many good things about them.
An IDMAX is a very nice sub, but even though I loved mine, I would strongly recommend auditioning anything before buying. Everyone has different taste, and regardless of how nice any sub is, there will always be people out there who will prefer something else.
What are opinions on the dynaudios? Heard alot of good things about those 240GTs...
Dynaudios are bloody nice speakers. When I first started getting into car audio, I heard a set of these which absolutely blew me away. They partly served as inspiration to me of how great a car can sound. Defiantely one of my favorites.
I would say I was after somethin with a bit of hit, as I listen to quite a bit of harder dance, drum and bass etc. Anyone got opinions on the Focal K2P's? And is there anywhere I can check out the prices of the rainbow gear? Or probably more to the point, what range of rainbow splits am I looking at for ~$1000?
For that cash, youd be looking at the Profi level of speakers.
There is the Profi line, and the Profi Vanadium line.
Both are available as either Standard, Kick-Bass or Phase Plug variants Further more, each (bar the phase plugs) is available as either a 2 or 3 way set, effectively giving 10 different options.
For abit of a rough summary:
Profi: Uses silk dome tweeters, and natrural fibre mids.
Vanadium: Uses aluminium tweeters and mids.
Standard: Speaks for itself!
Kick Use a more complex spider/motor structure to optimise 'punch' in the kickbass region.
Phase Plug: Uses an aluminium phase plug for an optimised midrange
I can't commend alot on the Standard line as I havent heard them.
I have however heard the Profi Vanadium Kicks, and Profi Phase Plugs (both two way). Did a back-to-back on the same day, in the same car, with all identical settings, and no sub running.
We concluded:
1) The Vanadium tweeter is
slightly more detailed in the top end, while the Profi has a touch less 'ting' but sound a little more warm. However, this is nitpicking, as the differences are very slight. I don't belive we would have picked a difference if we didn't run them back to back the way we did.
2) The Vanadium Kickbass driver had slightly stronger mid-bass then the Profi Phase-plug driver. Again, the difference was much smaller then we expected, but it was there. Both proved to have a very strong midbass, with the kick just giving out that wee bit more.
3) The Profi Phase Plug set had a little more midrange detail then the Vanadium Kick did. Yet again, the difference was quite modest, and probably only noticable due to the back-to-back nature of the test.
The way I look at it, the Kick is a standard version with extra midbass, and the Phase plug is a standard version with improved midrange. Hence, I'd imagine the Standard set would sound similar, minus the extras (hence - standard). Considering the kick still has nice midrange, and the phase plug still has nice midbass, I can't image this would be too much of a worry!
So basically, assuming all this is true, the range really does do just what it says.
If priority is midbass? Go with the kicks.
If priority is midrange? Go the phase plugs.
If you don't feel you'd notice the difference, and don't feel he need to spend extra, go the standard set.
If you like that little bit more 'tingle' then get Vanadiums - they are still very warm and smooth.
If you prefer a slightest bit more mellow, then go with the profis - they still have great 'tingle'.
If you have the cash, have room to work with, and dont mind a little more effort in the install then go with the three ways - else get two ways.
There are plenty of options, and my recommendation is if you can get an audition of either of the above, well installed, then it will give you a good indication of what to expect, as they are all similar in style. Then if you like them, and want a touch more of something, use the above list to help you choose.
In the given music, top and and midbass are probably more important then warmth and midrange detail, so i'd say the Vanadium Kickbass would probably be your best bet
