Full Version: Soundstream Re-Release Reference range.
Mobile Electronics Australia > Mobile Electronics Discussion > News, Press Releases & Industry Discussion
looks like Soundstream are re-releasing the reference range of gear.
whispers tell me it's just a repackaged version of one of there other amps.
QUOTE (From Soundstream Site)
What exactly is a ‘REFERENCE standard’? Well it’s a bench-mark you look-up to and endeavor to achieve; the standard you adopt as your own or refer to; and even by which you may chose to judge your own performance. Prior to the inception of Soundstream’s REFERENCE series of amplifiers, no other company had ever brought either of these concepts to the fore: all connections on one side, fully adaptable power supply for either SQ or SPL applications, the use of 1% and 2%
tolerance resistors and separate L & R level adjustments…yes we started it all and don’t forget that! Today thankfully, advanced technologies in small-signal processing and MEGA-FET power devices, makes it possible for a complete and faithful re-introduction of these phenomenal sound processing machines, minus the added cost of 2% resistors for example and high-count B-FET devices.
So, Soundstream is the absolute unmitigated FIRST to establish an audio amplifier REFERENCE standard for all others to follow and consequently, set it self apart from the rest that worked! There are definitely a lot of copy-cats out there today; trying to “steal our thunder”; but not to worry, we’ve huddled & planned for the follow-up, enter the new
REFERENCE (encore) series:
Every a bit a chip-off-the-old-block in terms of flawless sound reproduction PLUS; we have gone to work to introduce some serious enhancements like these: 4.5:1 Power Supply capacity to audio output power ratio, laser-cut precision gapped-core toroidal transformers, polystyrene caps in the input stages, high-speed JFET OP amps with high CMRR factors and precision tracking VRs.
GENERAL FEATURES
RUBI™ (Rapid-Use Branched Impulse) proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Trident™ amplifier protection topology
Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
Hawkins Bass Control™ Proprietary bass equalization topology
IDI™ (Intelligent Distress Indicator) gives visual indication of amplifier protection status
Harmonic Bass Alignment™ produces tighter, more accurate bass
Fully regulated MOSFET power supply
Triple Darlington Output Circuitry
BIP™ Bias Input Protection
Rail Stabilization Protection Circuitry
Bi-linear selectable two-way crossovers for amplifier and line outputs
Continuously Variable High and Low Pass Crossovers
Balanced Line Inputs for the Highest level of Noise Rejection
Gold RCA Inputs and Outputs
Gold 2-gauge Power Connectors
Tri-mode operation
does anyone else have any information on them?
i would guess they are doing a rockford, relesing old looking amps with new internals.
nemesis
holy crap they look identical, but i'd have to agree on assuming they're not going to have much on the originals sad.gif
but they don't use the '2%' resistors anymore... I'd think 1% would be preferable...
look sexxy tho
BMWTurbo
Hrrrmmm Interesting... I finally hunted down a pair of 'real' Ref's recently...
QUOTE (BMWTurbo @ May 9 2006, 12:36 PM) *
would love to open one of these and see what the go is inside...
MADTRAV
Where are these rumours originating from......
I believe they are the internals from the Van Gogh range, besides anything made after they've been taken over is garbage IMO
APS
All the latest Soundstream equipment is entirely made in China.
Stooge007
as is the majority of equipment these days.
does it matter to me?
blah, blah my amp was made in the USA blah, blah
anyway, would also like to see/hear one of these
- Stooge007 out
APS
I never said whether thats a good or a bad thing why do you assume its meant to be bad.
I just said that it is not the original Reference equipment as far as i know.
The latest stuff is Made in China.
Midol
I'd rather my stuff made in China than the USA. The amount of illegals in America chances are it is made by them anyway.
I would hope that a 'reference' amplifier was made to some standard of excellence, but then I guess that's marketing for you... who's reference is it?
BMWTurbo
Internals of the little Ref300 amp.
Rated 2x75WRMS 4ohm's
or 300WRMS into 1,2,4ohm mono.
old class A SS -
see how easy it is to make a good amp?
Old one looks nicer - more elegant design, like art.
new one just looks like engineers design.
BMWTurbo
QUOTE (Pulse-R @ May 13 2006, 03:39 AM) *
Both the images above, Fud's and my post are Original SS ref amps from the same Era.
QUOTE (BMWTurbo @ May 15 2006, 10:02 AM) *
the one i posted was a class A 100II a couple of years older but not much..
2 x 50W @ 4 ohms (<0.1% THD)
2 x 80W @ 2 ohms
1 x 160W @ 4 ohms bridged
Fuse: Internal 10A AGU for power supply, 2 x 5A ATC for output
Can be optimized for 2 or 4 ohms stereo and 4 or 8 ohms bridged
1 Ohm stereo stable
how about this - the davinchi
mmm 7 channels of goodness!
nemesis
I'm assuming the 7th channel is the fat terminals on the right, for the sub?
still not as old skool as the class A
QUOTE (nemesis @ May 15 2006, 10:10 PM) *
you know you want one Adam...
sell your soul to the devil and come back to the dark side mwhahaha
nemesis
QUOTE (fuddbutter @ May 16 2006, 12:32 AM) *
MADTRAV
QUOTE (fuddbutter @ May 15 2006, 12:14 AM) *
2 x 80W @ 2 ohms
1 Ohm stereo stable
And i know someone with one brand new in the box!!!
QUOTE (MADTRAV @ May 22 2006, 05:52 PM) *
I miss my old Ref Class A 6.0s........
jas
BMWTurbo
I want a Davinchi...
What do these sell for now? I love the idea of running a whole system from one amp smile.gif
dugald_bell
QUOTE (BMWTurbo @ May 24 2006, 08:15 AM) *
Well i did have 2 at one stage after coming back from Canada, unfortunately had to sell them both one in vgc the other ok i think i got 3k and 2.5k for them but that was 2.5 years ago. The better one also had an extra BLT although not gold plated like the original. I think one in new/mint condition would be worth tracking down as the gold plating is pretty thin and they scratch SOOOO easily! I will be looking for another as soon as i can afford it!
Damn those photos sure bring back the memories!
Rich
Ah yes, the old Soundstream... made long before 'Lil Wonder' monitors and stubbie holders sad.gif
it's just so phat. Damn phat.
Alas, like HiFonics, Orion, and many others, things aren't quite like they used to be. Even Alpine gives ratings at 14.4 volts and 2 ohms now sad.gif
