WHAT IS A CLUTCH?
A clutch is the device that couples the engine to the drivetrain. It is designed so that it
can be positively disengaged by depressing the clutch pedal. This disconnects the engine and
drivetrain. Releasing the clutch pedal engages the clutch, connecting the engine and
drivetrain.
CLUTCH SYSTEMS
When the clutch couples the engine to the drivetrain, it is transmitting the power of the
engine to the drivetrain. In a street or a race application, the smoother the clutch applies
the power to the driveline, the better the vehicle will perform.
Think of your clutch system in terms of the braking system. If you lightly apply the brakes
in stopping, the vehicle will stop in a smooth manner. If you stab the brake pedal, the
brakes are likely to lock up and a skid will occur. The same principle applies to the
clutch. If the clutch is engaged with too much pressure, the tires are likely to spin. When
the pressure of the clutch is controlled, the clutch is able to apply the torque of the
engine smoothly to the drivetrain without excessive tire spin.
Just like your brake system, over time the friction components of the clutch system will
wear. The more you use the brakes, the faster they wear. The more the clutch is slipped to
provide smooth engagement, the faster it will wear.
COMPONENTS THAT MAKE UP A CLUTCH SYSTEM
PRESSURE PLATE
This is the pressure mechanism that clamps the disc to the flywheel to get the vehicle
moving. Pressing in the pedal relieves the pressure from the clutch disc to disengage the
engine from the drivetrain for shifting or stopping.
CLUTCH DISC
The clutch disc is a flat plate with friction materials on both sides. As the pressure plate
is engaged (pedal let out), the clutch disc is clamped to the flywheel. When the pressure
plate is disengaged, (pedal pushed in) the clutch disc is unclamped. The disc is connected
to the input shaft of the transmission by the splined hub, causing the input shaft to turn
when the clutch is engaged, thus causing the vehicle to move.
FLYWHEEL
The flywheel is an inertia device that is bolted to the engine crankshaft. It has several
functions including carrying the ring gear the starter uses to crank the engine, storing
energy to get the vehicle moving from a standing stop, and providing the friction surface
for the clutch disc to be clamped to.
RELEASE BEARING
The release bearing is the actuating device that engages and disengages the pressure plate.
When the clutch pedal is depressed, the release bearing applies pressure to the fingers of
the pressure plate to disengage the drivetrain. When the clutch pedal is released, the
release bearing retracts and allows the pressure plate to apply pressure to clamp the disc
against the flywheel.
RELEASE FORK
The release fork holds the release bearing, and pivots on a ball stud as the pedal is
pressed in or let out. Pushing in the pedal pivots the fork towards the pressure plate and
forces the release bearing against the clutch fingers, pressing them in to disengage the
clutch.
PILOT BUSHING
The pilot bushing or bearing installs in the end of the crankshaft. When the transmission is
installed, the input shaft tip inserts into the pilot bushing, which supports the input in
the back of the crankshaft.
TYPES OF PRESSURE PLATES
The pressure plate applies pressure to the clutch disc to clamp it against the flywheel and
engage the clutch. Pressure may be generated by spring (static) pressure or centrifugal
pressure. Static pressure is constant, meaning that whether the engine is turned off or
spinning 7000 RPM, the pressure never changes. Centrifugal pressure is not constant. It is a
function of engine RPM. Centrifugal pressure is generated by the clutch levers and increases
to the square of the engine RPM. It is less pronounced at lower engine speeds but very
effective in the higher RPM range.
DIAPHRAGM PRESSURE PLATES
The diaphragm pressure plate utilizes a Bellville or conical spring to apply pressure to the
pressure ring. This type of pressure plate has multiple fingers that the release bearing
presses against to disengage the clutch. Diaphragm clutches rely completely on static
pressure which is unaffected by engine RPM.
The Belleville spring allows the pressure plate to be released and engaged with a relatively
light pedal effort compared with coil spring clutches. This design is used almost
exclusively in late model vehicles that have hydraulic or cable release mechanisms, due to
the lighter effort required to engage and disengage the pressure plate.
The diaphragm clutch is excellent for use in street and heavy duty street applications where
drivability and pedal effort are a major concern for the user.
CENTRIFUGAL WEIGHTS IN DIAPHRAGM STREET/STRIP APPLICATIONS
Some aftermarket diaphragm pressure plates feature a centrifugal weighting system.
Centrifugal assist is useful in drag racing and other high RPM applications to apply
additional clamp load to the clutch disc. The drawback to centrifugal assist in highway
performance applications is that the centrifugal assist is low until the engine reaches high
RPM. The load on the clutch (the effort required to turn the driveshaft) is very high at low
RPM and decreases at higher RPM. In most highway applications centrifugal assist is not
effective in increasing holding power or performance because it fails to solve the high
torque load at low RPM problem.
BORG & BECK PRESSURE PLATES
The Borg & Beck pressure plate uses three levers to engage and disengage the clutch disc. It
is a coil spring design, where the pressure of the clutch is applied to the disc using coil
springs similar to a valve spring. By combining these springs at a specific installed
height, different pressures can be attained for the pressure plate. Borg & Beck clutches
rely completely on static pressure which is unaffected by engine RPM.
Borg & Beck pressure plates are found in GM, Chrysler, and AMC early model applications with
mechanical linkage. Borg & Beck clutches and can be identified by looking at the width of
the clutch fingers, which is about one inch. The coil spring design by nature will require
more pedal effort to engage and disengage the clutch.
Borg and Beck clutches are best suited to street and heavy street applications in older
muscle cars and trucks.
LONG STYLE CLUTCHES
In typical Long Style pressure plates weights are added to the clutch levers to increase the
plate pressure as RPM increases. Pressure plates are the Ford version of a three lever, coil
spring pressure plate. Long is the most popular type of pressure plate for drag racing
applications. Its design is the basis for today's professional drag racing clutches.
The inherent advantage of Long Style pressure plates is their ability to apply centrifugal
clamping pressure. As engine RPM increases, the levers in the plate pivot against the cover
and apply additional clamp load to the clutch disc. This is true in both counterweighted
lever and non-counterweighted designs. (Counterweighted levers have provision for
installation of weights to the backside of the levers to further increase the centrifugal
clamp effect.) Some Long Style clutches feature adjustable static pressure. By turning an
allen screw located on top of the spring, the pressure can be increased.
Long clutches were prevalent in early Ford muscle cars and trucks.
ADJUSTING STATIC PRESSURE ON LONG STYLE CLUTCHES
Increasing the static pressure of a Long Style pressure plate is achieved by turning the
Allen adjuster screw COUNTERCLOCKWISE to increase the static load. When the screw is turned,
it pushed against the cover and the adjuster base compresses the spring, increasing the
spring rate. Most pressure plates have a maximum of 7 turns adjustment. Turning the adjuster
screw further will cause it to come out of the adjuster base. When this occurs, the entire
plate must be disassembled for repair. Some racers mark the turns they have in the clutch on
the side of the bellhousing in order to keep track of where they are set.
As the adjuster screw is turned counterclockwise, the spring is compressed to increase clamp
pressure.
CLUTCH DISC CONSTRUCTION
There are two types of clutch disc construction - solid hub and spring dampened hub.
Solid hub discs have the splined hub riveted directly to the disc carrier plate (the
circular metal plate that carries the friction material). This construction is typical of
all out racing discs.
Sprung, or dampened hub discs, do not have the splined hub attached directly to the carrier
plate. The hub floats in a spring loaded assembly on the carrier. When the hub is loaded as
when the clutch is engaged, the springs help absorb the load rather than transfer it
directly to the carrier plate. This arrangement allows shock spikes from aggressive
engagement to be dampened out to avoid possible damage to the drivetrain. This type of
construction is used in factory replacement discs.
Performance discs feature stronger damper springs to absorb higher loads. Most RAM
performance discs are equipped with RAM poly-coil springs, which are encapsulated in
urethane providing a substantial increase in the spring rate over stock springs. The
stronger spring prevents over travel of the hub and subsequent damage to the disc.
Selecting the correct disc construction is simple. Stock applications use the dampened hub.
From there, as loads increase, the rigidity of the hub should increase right up to solid
hub.
COEFFICIENT OF FRICTION
Let's say we have a box sitting on a countertop. It takes 3 pounds of pressure to slide the
box across the countertop. Now we place the box on a rubber mat. It takes 8 pounds of
pressure to slide the box across the rubber mat. The rubber mat has more grip, or a higher
coefficient of friction than the smooth countertop, thus taking more effort to slide the
box.
In terms of the clutch disc material, a higher coefficient of friction means that it will
take more load on the clutch to cause it to slip.
FRICTION MATERIALS
As performance requirements increase, it is necessary to step up the friction
characteristics and durability of the clutch facing materials.
ORGANIC - Organic material is common to all stock clutch discs, and offers the best
drivability but has limitations as operating temperatures rise. Under high loads accompanied
by slippage, they fade because their coefficient of friction drops off. In addition, at high
RPM and high temperature they tend to fail structurally.
KEVLAR COMPOSITES - Kevlar material offers a higher coefficient of friction than organic
material, but with some loss in drivability. As the coefficient of friction goes up in the
disc material, so will the aggressiveness of the material on engagement. This means that
some chatter can be expected with this material in low gear and reverse. Kevlar is
compatibile with stock flywheels and pressure plates, making it a good upgrade choice for
later model vehicles. We do not recommend Kevlar for competition.
BRONZE METALLIC - Bronze metallic (paddle discs) is the most aggressive materials in terms
of engagement. It offers extended life using reduced static pressures, and a quick, clean
engagement. Bronze metallic is aggressive on the flywheel surface and should be used only
with steel or nodular iron friction surfaces. On the street, this material will cause
chatter on engagement.
SINTERED IRON - Sintered iron is well known for its ability to withstand some slippage and
not loose its coefficient of friction. It is the material choice for high horsepower clutch
applications for drag racing and truck pulling. A key feature of the competition sintered
iron material is that it is maintainable. If the clutch is slipped excessively, the disc can
be resurfaced and reused.
DRIVABILITY VERSUS PERFORMANCE
With disc choices ranging from organic to metallic to sintered iron, deciding which material
to use is ultimately up to the end user, based on the type of performance and drivability is
desirable. When deciding, one must think about what is most important for the vehicle. If
on-the-track performance is the most important, select a disc material that is fairly
aggressive. But realize that making this decision will effect how smoothly the vehicle will
operate under normal driving conditions. If smooth and drivable is most important, select
the disc based on this. Keep in mind though, that the life of the clutch disc under racing
conditions will likely be reduced.
FLYWHEELS
The flywheel is primarily an inertia device. As the flywheel spins it stores energy or
inertia that helps move the mass of the vehicle as you engage the clutch.
Factory flywheels are designed to apply the optimum amount of stored energy to provide good
drivability for the vehicle. Vehicles with smaller engines have relatively heavy flywheels
due to the extra inertia needed for a smooth transition to engagement. Reducing the weight
of the flywheel, while increasing performance, could reduce the drivability of the vehicle.
Under racing conditions, the flywheel weight can be used to control the inertia applied to
the drivetrain. For instance, if a vehicle tends to ‘bog' upon engagement of the clutch,
increasing the flywheel weight will increase the inertia needed to launch the vehicle
smoothly. Too much flywheel weight may cause excessive inertia to be applied, causing the
tires to spin. Reducing flywheel weight under this condition will reduce the inertia applied
to the vehicle and allow smoother acceleration.
Aluminum flywheels are used in drag racing high horsepower applications which require the
clutch to slip as the vehicle leaves the line. Steel flywheels are used primarily in street
driven vehicles.
GEARING AND FLYWHEEL WEIGHT
Other load factors can effect flywheel selection, such as rear gearing or transmission
gearing. With the abundance of gearing choices available today, it is possible to use almost
any flywheel if the proper selection of gears is made. This was not always the case in the
70's when the gearing choices were not available, racers had no choice but to use the
flywheel weight to control the vehicles on launch. It is more efficient to use a light
flywheel and proper gearing than to use tall gearing and a heavier flywheel.
FLYWHEELS AND DRIVABILITY
Selecting the proper flywheel helps you achieve the drivability you desire for your vehicle.
Heavy streetcars will benefit from a heavier flywheel to generate the inertia to get you
moving. An aluminum flywheel will not generate as much inertia to move the vehicle, and thus
it would be necessary to slip the clutch more on takeoff. Some street vehicles may benefit
from a lighter flywheel, but only if there is enough rear gear to help you transition the
clutch smoothly without excessive slippage.
HOW DO I SELECT THE PROPER FLYWHEEL?
When we are asked for a flywheel recommendation, several factors are considered to make a
proper recommendation:
- What is the primary use of the vehicle? For street driven vehicles, a steel flywheel will
provide easier engagement and longer clutch life.
- What is the rear end gearing? Lower (higher numerically) gears will make engaging the
clutch easier, while higher gearing requires the clutch to be slipped more on takeoff for a
smooth transition.
- What is the weight of the vehicle? If it is over 2800 pounds, we will generally recommend
steel.
Remember the flywheel's job is to get the car accelerating smoothly. If you have ever driven
a vehicle and tried to pull off in second gear, you know you had to slip the clutch
significantly more to get moving than if you started in low. This is the same effect you
would notice if the flywheel is too light.
RELEASE MECHANISMS
All clutch systems require a release mechanism to operate the clutch. There are several
types of systems that have been used over the years by the various manufacturers.
MECHANICAL LINKAGE
Mechanical linkage is most prevalent in vehicles produced pre-1980 and in race vehicles. It
usually consists of a bellcrank that pivots between the frame and the engine block. One side
of the bell crank attaches to the clutch pedal, and the opposite side attaches to the
adjustment rod for clutch release. The adjustment rod is inserted into the clutch fork and
lengthened or shortened to achieve the proper release and gap between the clutch fingers and
the bearing. Typically the ratio between the release mechanism and the pedal effort is
between three and four to one. Mechanical linkages provide the most flexibility in clutch
adjustment.
HYDRAULIC SYSTEMS
Hydraulic master/slave release systems are common in vehicles produced after 1980. This
system uses a master cylinder mounted on the firewall and a slave cylinder, usually mounted
on the bellhousing. A hydraulic line connects the two. The slave cylinder will usually have
a rod that fits into the clutch fork and either pulls or pushes the fork when the pedal is
depressed. Some hydraulic systems incorporate an adjustable slave cylinder, where you can
manually set the clutch release. Some later GM systems use non-adjustable slave cylinders
and are more difficult to deal with when installing non-stock clutches.
Often when changing clutches in vehicles with non-adjustable hydraulics, if the flywheel is
resurfaced more than .020 inch, a flywheel shim must be used between the crank flange and
the flywheel to shim the flywheel to its original position. Since the slave has no
adjustment, the only way to make these systems function properly is to have the pressure
plate mount so that the fingers are in the exact same position as stock in order for the
clutch to release properly.
CABLE RELEASE SYSTEMS
Cable release systems use a cable connected to the clutch pedal and the clutch fork to
actuate the release bearing. When the clutch pedal is depressed, the cable is pulled and in
turn pulls the clutch fork to disengage the clutch. Most cable systems are self adjusting,
using a ratchet mechanism mounted under the dashboard to keep the release bearing in
position for the clutch to release.
Aftermarket adjustable cables are available for many aftermarket clutch systems, the most
popular being the late model Ford Mustang.
INTERNAL HYDRAULIC RELEASE BEARINGS
Internal hydraulic release bearings are the newest release systems used in late model
vehicles. Typically, a slave cylinder that houses the release bearing mounts to the rear of
the bellhousing or on the front of the transmission. A hydraulic line connects the slave to
the master cylinder mounted on the firewall. When the clutch pedal is depressed, the slave
cylinder pushes the release bearing out and disengages the clutch. Most of these systems are
non adjustable and require the clutch to install so that the fingers are in the stock
location, or the clutch may not release. You may also hear these bearings referred to as
concentric release bearings.
Internal bearings are not new to the aftermarket. Several manufacturers have produced these
units for use in oval track racing, where space limitations preclude using a fork release
system. They are also very popular for kit car installations.
TYPES OF RELEASE BEARINGS
Two types of bearings are used for these release mechanisms. Standard release bearings have
the bearing and race pressed on the bearing collar. The bearing is static on a standard
bearing. SELF ALIGNING release bearings are assembled in the same manner, but have floating
design that allows the bearing to move about on the collar so it can find its exact center
once it comes in contact with the pressure plate fingers. Self aligning bearings are used in
most all late model applications.
