Alright,
so I'm getting close to reinstalling my Ute sound system.
and I can't fkin work out which way I want to install my amps and wire them up.
Here is what i Have.
2 x Focal 27kx subs 4 ohm, Need 300-800W each. (with 800W these can EASILY be overdriven, 800w really not required)
2 x Focal K2P Midbass, Need 100-200W each
2 x Focal 100KP Midrange Need 100W each
2 x Focal TN52 Tweeters 8 Ohm need 50-150W
2 x Focal X/overs (optional)
Amps.
2 x Soundsteam Van Gogh 800.2 (200 x 2, or 800 x 1 each @ 4 ohm)
1 x Soundstream Van Gogh 1600.2 (400 x 2, or 1600 x 1 @ 4 ohm)
1 x Soundstream Van Gogh 500.4 (125 x 4 or 500 x 2 @ 4 ohm)
Note that None of the amps can be run 2 ohm Mono.
I have no wiring capability/neccessity to run 2 ohm stereo.
The system will be run either fully or semi active.
Here is my dilemma, how and which amps to use for what.
System design is No1. Sound Quality, No2. Output.
So here is my options.
TCPO = Total Configured Power Output.
Option 1. - Active/Passive - TCPO 1600W
1 x 1600.2 running Focal 27kx Stereo 400W Each (or bridged 800 x 1 at 8 ohm)
1 x 800.2 running K2p Midranges 200W each
1 x 800.2 Running 100KP Splits with passive X/overs 200 x 2
500.4 spare (doing nothing)
Option 2. - Active/Passive - TCPO 3400W
1 x 800.2 Running 27KX 800W x1
1 x 1600.2 Running K2p midbass 400W each
1 x 500.4 Bridged Running 100KP's Passive 500W per Side
Option 3. - Fully Active - TCPO 1575W
1 x 1600.2 Running 2 x 27KX 400W each (or bridged mono 800w x 1 at 8 ohm)
1 x 800.2 Running K2p Midbass 200W each
1 x 500.4 Running 125W into each Midrange, and 125W into each tweeter (actually 62.5 since tweeters are 8 ohm) using Amps supplied 12db X/overs actively.
800.2 Spare (doing nothing)
Option 4. - Fully Active - TCPO 2775W
1 x 800.2 Running Bridged 27kx 800W x 1
1 x 1600.2 running K2p Midbass 400W x 2
1 x 500.4 Running Actively 125W x 2 into 100kp midbass, 62.5w x 2 into TN52 Tweeters
Option 5. - Active/Passive - TCPO 1800W
1 x 500.4 Bridged running 2 x 27kx at 500W each
1 x 800.2 Running k2p's 200W each
1 x 800.2 Running 100KP splits with passive X/over 200W a side
1600.2 Spare
It's important to note, this is being run off a 8053 head unit,
so I have front mid/tweeter x/over with 5 band eq and separated time alignment,
to use for the mid/tweeter
rear x/over with 5 band eq and separated time alignment for midbass
and sub out separated (stereo or mono) time alignment.
all the x/over points are totally adjustable, with the exception that the 100kp, either run passive or active from the amps x/overs.
Power supply is no issue, running Dual Yellow tops + 20 farad Cap. Lots of 0 gauge!
so .. i'm in a conumdrum.. what do i do.
and don't both replying here, if your going to tell me to buy something else or what i Have isn't right ect.
I want replys based only on what I do have.
Juls
