Full Version: Ghost wiring
Sir-Psycho-Sexy
I had an attempt at ghost wiring an absolutely screwed earthquake amplifier, just because I could. Once I'd finished it looked fine from normal angle's but under neath looked really dodgy. It looked like all the wires could have shorted out any where. I'm not going to attempt to try and wire it in again so don't worry.
How do i go about ghost wiring an amplifier propperly?
SirNemesis
What the hell are you talking about?
MatS
I think he's talking about rewireing the inputs/outputs of the amp, so they are not visable in an intalation. i.e. making them all come in/ou from under the amp. yes?
20Hurtz
why can't you jsut trim the wires that are sticking out or what ever?
a common tactic is to make up a "cover plate".
Think of a shallow box the amp sits in, with one end open. All your power/speaker wires go in this end. then, you make a plate up in the form of a photo frame, like a hollow rectangle. you put this over the top, and the frame borders cover up the end of the amp, where all the wiring is.
Simple, neat, and effective. Do you need photo examples of what i mean?
MatS
Photos are always a good idea! would help explain to everyone atempting it.
SPL_Lancer
Could he also be talking about 'hardwireing' the cables into the amp?
Sir-Psycho-Sexy
QUOTE (Liquidity @ Jun 8 2006, 05:30 PM) *
No no, i understand.
Chris guimelli's supra was the one that made me think ghost wiring so I had a go. (couldn't fing any pic 's but it's the halequin one)
Stooge007
false floor, top of amp sitting flush
- Stooge007 out
Sir-Psycho-Sexy
QUOTE (x 2 tha z @ Jun 8 2006, 05:54 PM) *
yeh it probably is the same
QUOTE (suthosutho @ Jun 8 2006, 04:45 PM) *
Yep
MatS
What do you mean by "It looked like all the wires could have shorted out any where"?
killaklown
I dont believe u are talking about hardwiring, that is where u go thru the chassis off the amp bypassing the terminals and connect your wires straight to the circuit board.
You are talking about hiding your wiring as if it is not there so anyone looking at it thinks that it just works with no wiring yeah??
if so its a case of making a cover plate, also kicker amps are good for this as they have the big end caps which give u heaps of space to pass the wire behind
MatS
i thought he was talking about "hard wiring".
As in directly to the PCB. in order to give a floating effect without wiring been visable.
TEGBOY
QUOTE (suthosutho @ Jun 10 2006, 12:10 AM) *
Agreed, exactly what I thought.
He is wanting to wire the amp up, with cabling being visable and without having to recess the amp behind a trim panel.
Sir-Psycho-Sexy
QUOTE (killaklown @ Jun 9 2006, 06:25 PM) *
QUOTE (TEGBOY @ Jun 10 2006, 09:50 AM) *
Hard wiring , Ghost wiring sounds like its the same thing. "u go thru the chassis off the amp bypassing the terminals and connect your wires straight to the circuit board."
I knew that alpine and kicker make these cover plates but I'm not really fond of either range.
"You are talking about hiding your wiring as if it is not there so anyone looking at it thinks that it just works with no wiring yeah??" - that's the jist of it.
I wasn't ever actually going to use the earthquake amp with what I had done because where the wires had gone through the backplate bare wires where way to close to the body of the amp. Also I never thought the amp would actually work.
spl_MAGNA
heres my boot "ghost wired" or as i tell people, "done good so you cant see wires and $hit" im just waiting for some beauty panels to be made up but this'll do for now, oh and theres also another pic i found humerous, enjoi!
Sir-Psycho-Sexy
I reckon that looks awsome!!
I also reckon that a bit of quality wiring on display, neatly, can look equally fantastic.
"semi-ghost" wiring.
Woob
ive always wondered how hard it would be to redirect the terminals from the underside of the amp so they are still connected to terminals, but invisible from the front. although this wouldnt work with rca's everything else would work fine smile.gif
those pics are pretty insane
Sir-Psycho-Sexy
QUOTE (Woob @ Jun 15 2006, 01:36 AM) *
It didn't look that hard to rewire the RCA's through the bottom of the Earthquake amp. Just abit of accurate soldering.
Gordo!
Chris' ghost wiring:
Click to view attachment
As you can see, it's no half-assed trim panel job! It's full blown hardwiring through the base of the amp. Don't thank me for the picture, just throw money.
Sorin-Andrei
put it in the coinslot i presume?
Sir-Psycho-Sexy
Thanks for the pic!
That's the exact one I was thinking of.
Do you want my credit card, I'm all out of cash
