I’m on the verge of buying another amp and because I only want to run two amps, it will determine what head unit I buy and whether I run the system passive, semi active or fully active. The gear I already have are Focal K3Ps, a Boston G512 DVC sub and a Boston GT-42 amp. If I go fully active I would go for a Clarion HX-D2 or otherwise a Pioneer P80RS.
I’m trying to decide between another Boston GT-42 (4ch) or a GT-28 (2ch)
If I get another Gt-42 I can go fully active but the sub will be a little underpowered, yet adequate. The GT-28 will be more than enough for the sub in fact enough for two if I want to add another later but I can only go semi-active or passive. The choices I have are as follows.
PASSIVE
I could bridge the GT-42 to run left and right (rather than front and rear) which can give me 350W each @ 2ohms to drive the K3Ps. The GT-28 will drive the sub 1000W @ 2ohms
PASSIVE or SEMI ACTIVE
Using the GT-42 for the front I would run the midrange and tweeters off the front channels and the mid-bass off the rear channels which gives me 75W each @ 4ohms. Once again the GT-28 will drive the sub 1000W @ 2ohms
FULLY ACTIVE
Using two GT-42 amps Each driver gets 75W @ 4ohms and the sub gets 350W @ 2ohms
My questions are:
If going fully passive I get the most power by bridging but I understand that bridging is not the best for sound quality but how much does it affect it?
If going passive or semi-active how much control would I probably have over the tweeters?
If going Fully active I won’t be giving the sub as much power but is that much of a big deal? I have tried the G5 off the rear channels of the GT-42 and thought it would be okay but if I heard it off 1000W it could change my mind!
Overall I would like suggestions as to which amp to buy and whether to go passive, semi-active or fully active.
Doug
