Please note: I’ve assumed you already know how to take the tissue box holder out, so I’m not going to get into that in this post.
Here is the best place to run the power cable if your car is an auto. To remove the grommet, simply push it through into the cabin, from the engine bay. The little tab on it is to help you put it back on if you need to.
Just drill a hole in the grommet.
If your car is manual, then obviously you can’t use this.
When you remove the tissue box holder, you will see a plug behind it which goes to the cigarette lighter. Here is your source for GROUND and ACCESSORIES. Also taped to that loom is a light socket. There is your source for illumination if you wish to use that to dim your headunit.
The other wire you see there wrapped in foam is the antenna wire. That is normally tucked up to the bottom of the ICC, just pull it down and you will find where it plugs into, so you can unplug it from the factory deck and plug it into your own.
When you cut the plug off, make sure you leave some wiring on it so you can attach it at a later date if need be.
You will see a plastic tab at the back of the consol, with a hole in it. Cutting that off helps with getting the deck in, especially if you have quite a few wires at the rear as I did.
That’s all there is when it comes to the wiring side. You will need to run your own CONSTANT power. Mine comes from a distro block I have under the seat. Just make sure, where-ever it comes from, that it is fused! I can’t stress that point enough.
To make the facia, get some 12mm MDF and cut it to shape as shown. 222mm on the top, 213mm on the bottom. I forgot to measure the height but you get the rough idea on how to build it.
With a rectangle cut-out in the middle, you can mount the cradle that should have come with your deck. Just put it in place, and bend the tabs, as can be seen in the photos if you look closely.
You can also see how it is fixed to the dash, with the copper wire screwed in to the back. In the last photo, you can see a hole in the side of the facia. That stops the facia from swinging on the copper wire mounts. They are positioned in such a way that the tissue box holder will cover up the holes you use in the consol for the facia.
The paint used for the facia is SNB 150 Desert Rose Met. The can is available from Autobarn and is a perfect match for the rest of the dash.
And here is the finished product. Hope this helps!
