QUOTE (Selfdestruktor @ Jun 24 2006, 11:50 PM)
I ran a laptop on one for a while from my glovebox and never heard any interference in my system.
Just as long as it's at least 30cm away from your RCA cables (if you have an amp) you should be fine.
As for using the splitter, it depends on the total current draw from both devices at once. Your ciggy lighter system will be rated at either 10 or 15A.
The Playstation is 5-6amps I think, and the screen should only be around 1-1.5amp at the most, so you should be fine, but check them anyway.
well, i have rca cables running through the centre of the car to the rears. Now, if i put in an inverter, or get a ps2 slim and buy a ciggy adapter (which i believe i can buy from jb for cheap), wouldn't that interfer with the rca? how can i avoid this?
especially if i wanna hardwire the ps to the ciggerette lighter behind the dash?
