QUOTE (jas @ Jul 1 2006, 12:29 AM)
sorry didnt read your post properly
fuses amp one 30amp + amp two 2 x30amp...so id use a 100amp inline fuse...but i know that you should have no problems with a 80amp fuse
4 gauge kit with 80amp fuse should do the trick. but if you can id use 100amps...if you can get a kit with that...else use the 80amp kit and if that blows replace it with a 100amp fuse.
When working out the fuses remember that their are two points you want to fuse. one is at the battery and this is the fuse for the power wire.
with this if you use:
8 Guage you want no more than a 60 AMP fuse for it to protect the wire
4 Guage you want no more than a 100 AMP fuse for it to protect the wire
Then when you split the power wire into each amp you are either going to split the power wire into two of the same size wires i.e. one 8 Guage from the battery then split to two 8 guage one to each amp. If this is the case then you do not need to fuse the wire as it will be protected by the main fuse.
BUT if you split to two smaller wires i.e.
One 4 guage from the battery and then split to two 8 guage one for each amp you must fuse each 8 guage with no more than a 60 AMP fuse each (normally here you would fuse to no less than the total combined internal fuses and no more than the total the power wire can handle)
Now the main fuse should be as close to the battery as possible. the smaller fuses should be at the point where the wire is split to the two smaller wires usally using a fused distro block.
If i have totally confused you i can find the web link that normmaly shows up in these type of threads that will give you a full explination on how and why you need to fuse a wire correctly.
