In the router setup, Turn off SSID broadcast (This stops the unit from broadcasting its name/ID, so it wont come up as a 'found network' when someone searches for any available networks) and setup a WEP key to encript the data .. With this key, when you attempt to connect to the network it will prompt you for the WEP key (similar to a password, 64bit is 10 digit and wont communicate with the network unless the key has been entered)
just turned SSID off (now does this mean that wen i turn my comp on that it wont connect automatically or?)
i also have a 128bit WEP key, which i set up wen installing the router...
Most of the wireless modems I have worked with also have a MAC address filter. So you can specify which MAC addresses can come through. Turn this on (If it's available) and just add the MAC addresses of your PC's.
any more details about this? i didnt see it anywhere?
If your router has it. use WPA-PSK encyption. WPA-Pre-shared-key.
yeh it has that, wen i was setting up the router it gave me the option, but i wasnt sure, so i went with the default which was WEP and 128bit key... any more info on this please? wots the difference? is it similar to setup?
since the wireless is for the laptop, if it shortens battery life then it may be no good? tell me details anyways, so ill try it and see...
thanks alot, anything else?
- mad89
