QUOTE (Angelo @ Jul 4 2006, 11:46 AM)
The battery is a BOXTER model, the company is Dr Crankenstien.
If you can see a picture of it you will freak out, the terminals are the whole lenght of the battery and are 2" wide of solid copper.... and built to 800 cu in....
Introducing the Boxter crankenstein
This this is a f***ing nut battery. Can't read the specs though cause i can't read danish lol
12 Volt dB-Drag Batteri
High Capacity Batteri. Startstrøm CCA 110 amp, Startstrøm HCA 3400 amp. Kapacitet, C20 90 AH, Kortslutnings niveau 9000 A. Fylde 12,464 cm3, Dimensioner: H: 17,6. B: 38,7, D 18,3 cm. Vægt/Weight 37 Kg. Stk./Pc.
