You can get the manual
here if you dont have it.
In there it says a box volume of either 2.2 cubic feet (62.26 Liters) for SPL, or 3.7 cubic feet (104.71 Litres) for SQ.
So, according to the manual, the box will have to be: 31.5" x 20" x 13" assuming a wall thickness of 0.75" (assuming SQ use)
And again in metric: 80cm x 50.8cm x 33cm assuming a wall thickness of 1.9cm
That sub isn't really suited to use in a ported box. If you really have to have it ported, let me know the inside diameter of the port you will use, and I'll calculate the length required.
