Hi guys, in the next few days i will be installing 6.5" splits in my 2000 commodore VT series2. Before i go pulling anything apart i wanted to check here to see if i have the correct method for getting access to the factory location of the tweeters. I have read the PDF file on the dash setup that is available on this forum, and i think ive got it down, just want to confirm that these are the steps.
Drivers Side:
1. Remove 3 screws on side of dash
Click to view attachment
2. Remove screw under the previously removed cover and unclip/remove demister and tweeter cover assembly.
Passenger Side:
Same as above, but you need to remove these 4 screws on the inside of the glovebox in step 1 also
Can someone whose done this please confirm these steps?
Also, when i get it uncovered, will it be simple to run the tweeter wires? (ie is there an 'obvious' path) or is there a special path that needs to be followed?
Cheers,
Davey
PS i plan on making a longer post with photos as i do it and a headunit so everyone else who comes looking can find it easily!
