lould fj40 man
Jul 11 2006, 07:53 PM
can i put racing harnesses on the front seats and still have rear seats and able to move the seats foward. where do the anchor points need to be.
Jul 11 2006, 07:55 PM
this needs to be down the bottom in the garage section, maybe a mod can move it.....
VB-
Jul 11 2006, 09:08 PM
all the points i have seen are ether on a roll cage, or the rear seats are gone, i doubt you could have the points on the floor right behind the seat. and as far as i know, you can adjust the length on harnesses, just like on the rear seatbelt in old cars, but you will have to adjust it everytime u move the seat.
will there be other people driving the car and need the harness? ie: if its just street driving, if some-one borows the car, they can use the normal seatbelt which i htink has to be left in place as a legality, could be wrong on this though
philz
Jul 11 2006, 09:38 PM
Um u gotta have it either connect tot he rear seats or a rollcage, cause the harness bend can't be more than 45 degrees, or 20 degrees, can't remember which one..
Hence on the front seat is illegal, cause the bend is like near a 90 degree angle.
BTW, u do know how uncomfortable they are to use in street driving right?
ie/ u are strapped into the seat, and if u are a give way sign, or stop sign, checking for cars, its nearly impossible to reach your head out to check for traffic, and i wouldn't want to know how you would do reverse parking..LOL
bob
Jul 13 2006, 04:32 PM
Mmm racing harnesses in a street car...
Do you wear shin pads when you walk to the shops too?
_Anthony_
Jul 21 2006, 06:24 PM
QUOTE (bob^ @ Jul 13 2006, 04:32 PM)
Gold
Jul 21 2006, 07:46 PM
As mentioned
1) you must have a roll cage OR
2) you must take out the back seat, then get your car re-engineered/classified as a 2seater.
if you try and do the "90 degree" angle for the top two belts, you'll snap something in an accident, most likely your back. its illegal for a reason.
