Item Condition: Very good condition, no dents, no rust
Reason for selling: Bought another car
Price: $4700
Payment Method: Pickup - Cash
Extra Info:
Kilometres: 265,000 (engine has done 170,000km)
White in colour
Gen 1 3sgte Motor
Stock Ct26 Turbo
Stock Water to Air intercooler
ST185 4wd gearbox with locked transfer case, customised crossmember to suit (Has a slight crunch in 4th if you are quick).
GT4 driveshafts
Bosch Blow off Valve
Lightweight flywheel weighs 6kg compared to standard 9kg
3 puc brass button clutch
Dash Cluster and Climate control from a ST165
ST185 Carlos Sainz Bonnet Scoop
GT4 Brake system
DBA slotted rotors all round
EBC greenstuff front pads and Blackstuff rears
King springs low all round with KYB gas shocks
Whitline 27mm front swaybar
Whitline 18mm rear swaybar
2.5" turbo exhaust system with hi flow cat and resonator
Kenwood head unit with 6" front speakers customised to the doors
Comes with standard 14" rims!
This car is very quick for what it is!!!
With this motor i've heard of 1/4 around the 14.7 mark on 6psi.
Would be strong enough for 10-12psi
Engineer certificate is included
Just needs roadworthy and registration
