Liquidity focals top of the range speaker Grande Utopia Be incorporates a 15inch woofer for its lowest frequencies, and 11inch woofer for its more mid bass frequencies and 6.5inch speakers for midrange...this is in one speaker enclosure there are also tweeters etc....i was researching home audio earlier this year and it is common place for tower speakers to incorporate multiple 8 inch drivers....also a lot of high end audio will utilise 15inch sub woofers or larger simply because they are trying to reach frequencies below 20hz accurately....if you still dont believe me pop over to CAA's sister site Planet Audio and express your opinions about how nobody uses 8 inch midbass drivers and 18inch subs and you will be 'politely' and i actually mean politely told without abuse that it is actually commonplace to feature these size of speakers in a home audio enthusiasts system....here are 10 subs that come in 18inch for home audio use
1)Yamaha Speaker - CW118V 18 Inch Cast Frame Driver, 1200 Watt, Bass Reflex Design, Steel Grilles
Part No: CW118V
2)Electrovoice Subwoofer - I-Sub 18-Inch High-Output, 400-Watts
3)Electrovoice Cabinet Speakers - Eliminator-KW Dual 18-Inch Woofers, 1000-Watts Continuous
4)Peavey QW 118 - 18 Inch Subwoofer
5)Peavey QW 218 Dual 18 Inch Subwoofer
6)Cabinet Speakers QW Series - 800 Watts, 18 Inch High-Powered Woofer, Lightweight Design
7)Cabinet Speakers QW Series - 1600 Watts, 18 Inch High-Powered Woofers, 16-Gauge Powder-Coated
8)Peavey Subwoofer - 00496010 8-Ohms, 18-Inch Lo Max, 2400-Watts High Performance
9)EAW Speakers - VRS18 - 18 Inch 2-Way Full Range Speaker 500 Watts - 90 x 60 Horn
10) DD 9918
and here are 10 8inch speakers that are used for home audio
1)Electrovoice Speaker -Sx80BE 8-Inch Woofer, 175-Watts, Neutrik Speakon Connector, 2-Way System
2)QSC Loudspeaker - AD-S282H Surface-Mount Two 8-In. LF Transducers 90°H x 60°V 2-Way - Paintable
3)Behringer Business Speakers CE1000P 300-Watt,8 Inch Woofers,High-Resolution Driver 2-Way System
4)Yamaha Cabinet Speaker - AS108II 280-Watts, 8 Inch Two-Way Acoustic Suspension System
5)TOA Speakers - F-505G 8 Inch, 240 Watts, Input Panel with Push Terminals, 2-Way System
6)Atlas Sound Loudspeaker - SM8CXT-B 8 In. Coax.
7)Samson Monitor - Auro 8 2-Way Playback Ported Cabinet 55W 8 In
8)Sony SS-MF750H 200 watts maximum input power 3-way, 4 driver floor-standing speaker Dual 8" bass driver, 3 1/4" mid driver, 1" dome tweeter
9) Mirage 350 8inch woofer
10) Focal Diva Be 2x8" W-type cone woofer, 1-1/2" double coil, 4-4/5" magnet, 6-1/2" W-type cone midrange, 1-1/2" coil, focus plug, "Power Flower™" magnet system (patent pending), Pure Beryllium inverted dome tweeter, 3/4" coil, "Focus Ring™" magnet system (patent pending)
theres 10 of each....
so SA assistant state rep how about an apology?
