mr_g100
Jul 25 2006, 10:42 PM
lol
i have know idea what sub to get or amp to power it
i would like to get a comp 15incher and amp to match
i would like to get into the 143+ db area
i know i'll probaly get flamed for asking for help but hey what are forums for?
please help
no budget atm but i would like all variying prices and all
aiight
Nate
Charger
Jul 25 2006, 10:48 PM
Pair of DD Z1s and a DD 9915. Dual 1ohm coils always a good combo. Run the amps strapped at 2ohms daily and .5 for burps.
Budget around 6k but it doesn't stop there, don't forget battery, cabling, enclosure etc. It soon all adds up.
Woob
Jul 25 2006, 11:15 PM
DD 3515 and 2 Response 1500W monoblocks strapped and a nice sub box should see 143dB EASILY in a Charade
add a D31 Yellow top battery
4ga from main batt to Optima for charging
battery isolator
a few fuses and a bit of 0ga wiring n some lugs
some sound deadener
shouldnt cost more than about $2700
could een get closer to the 150dB mark with enough preparing
mr_g100
Jul 26 2006, 07:21 AM
2700 including sub amp battery and cabeling
Damn thats awsome
lol you gotta love mini cars aye
edit: stupid question, but where can I buy DD gear from
Woob
Jul 26 2006, 08:09 AM
DD_Phil will point you to someone close by
give him a pm (or he's bound to see this thread soon)
Jul 26 2006, 08:12 AM
What area of Queensland?
What's your budget? Even a 1015 or 2515 could do the job, depending on amp(s).
A customer on the Gold Coast runs two 1010s and a C2 in an Excel, he was getting mid 140s for under $1000.
Michae1
Jul 26 2006, 08:22 AM
Get down to Cartunez on the coast.
23 Wrights Place, Arundel.
mr_g100
Jul 26 2006, 09:01 AM
QUOTE (DD Phil @ Jul 26 2006, 08:12 AM)
logan area:P
waiting 4 tax return as i still havent got a group certificate
so these 1010s i'm guessing they7 are 10s right?
if so that'll prob suit my style of tech music
under a grand thats fu*king awesome
when i get tax return i want
nate
Jul 26 2006, 09:15 AM
QUOTE (mr_g100 @ Jul 26 2006, 09:01 AM)
logan area:P
nate
I figured you wanted a 15 for that Autobarn SPL class?
If not, go with 1012s, the 12" version, just as fast and punchy, but louder than, the 10s.
I'd see Brad at Car Tunez, he'll sort you out.
CHEETR
Jul 26 2006, 03:23 PM
where can u get dd gear in vic?
hsvmonarogen3
Jul 26 2006, 05:03 PM
tower audio. melton or oakleigh.
or get phil to send some stuff down!
Shreknos
tower audio....
philz
Jul 26 2006, 05:18 PM
how much are the 1000's rrp?
i think they went up in price? the "1000a" ones
hsvmonarogen3
Jul 26 2006, 05:28 PM
1015a - 349
1012a - 299
1010a - 279
1008a - 279
mr_g100
Jul 26 2006, 06:31 PM
1015a - 349
1012a - 299
1010a - 279
1008a - 279
what are the 1015a's like would still like a 15 for some reason
my 15 still keeps up with my tech so f*** it 15=louder (i think)
also whats this about Power Handling RMS/Music/Peak
500/1000/2000
found on DD website os 1000 what i normally use? or what
dont get me wrong i know the diffrence between RMS and Peak just dunno what Music is?
nate
Jul 26 2006, 07:17 PM
RMS - what it will take playing a full sine wave continuously
MUSIC - recommended continuous amplifier power for music
PEAK - SPL "burps"
I've run 2600Wrms into a pair of 1000s before, when Autosalon tested the 1008 we ran over a 700Wrms pure sine wave for several minutes non stop….
mr_g100
Jul 27 2006, 09:56 AM
spl burps thats after you've had the car Db tested to see frequency its best at
then you make cd with that on
for comp you Burp it ?
dont totaly understand burping though
oh and what are the 2515's like better or not?
nate
Jul 27 2006, 11:02 AM
QUOTE (mr_g100 @ Jul 27 2006, 09:56 AM)
nate
The 1000 range has a single 4 ohm coil, steel frame and 600Wpower handling
The 2500 range has dual 4 ohm coils, a cast basket and 1000W power handling
Dual coils can be an advantage if you are running an amp that makes power at lower impedances.
mr_g100
Jul 28 2006, 08:13 AM
what the diffrence in price?i know the 1015s are $329 but how much for the 2515? and even the 3515?
what amp would be best? would like to keep it as cheep as possible aiight
(let me guess everyones gonna say the Jaycar mono 1500W@1ohm)
found this amp
the DD M1a
1200WRMS perfect 4 the 3515d now all i need is prices on them and i can afford them
Jul 28 2006, 08:48 AM
Here's our whole pricelist, it's also on FHRX.
mr_g100
Jul 28 2006, 02:43 PM
lol i think the 3515 and 2515 are a little out of my price range lol
though i'm thinking the 1015 is still a good budget sub
am i right?
and i'm guessing its just a singe 4ohm voicecoil so i'm guessing that the DD MB2 will be best and may still be in my price range
with 500wrms be ok in a 600wrms sub or am i overdriving the amp?
if so what other amps out there are capable of doing the job around the same price bracket
are there any cheaper amps that'll do the job or what?
aiight
Nate
mr_g100
Jul 31 2006, 07:32 PM
just wondering if anyone will help out?
xplodea
Jul 31 2006, 08:10 PM
if you are only after a budget set up, why are you over looking jaycar? It boasts 800wrms at 4 ohm, which would suit your 1015 perfectly.
When you are asking these questions it sounds as though you are asking our permission, the best advice i can give you is go out and demo the subs for yourself, its the only way you will know for yourself.
James.
P.S. there is much more invloved then getting a sub and an amp and pushing the on button. You have to look at inclosure size/cost, wiring, sound deadening etc. Just something to think about. SPL isnt a cheap "sport."
Jul 31 2006, 08:39 PM
Don't worry about a 500W amp being "over driven" by a 600W woofer, it doesn't work that way.
Even if a woofer can handle 600Wrms, it will still run fine off a 100W amp.
mr_g100
Aug 1 2006, 06:05 PM
lol i just started thinking and i thought about keeping my Pioneer TS-W38C and just bumping up the power lol but then again if i was to get the jaycar mono 800wrms is heaps 4 a 350wrms sub lol i think its a 700w max lol lets see if it'll live or not
though on the other hand getting the 1015 would be awsome and if i was able to afford the 2515a and jay car amp that would be even better
in my understanding i'm thinking that the 2515a is dual 4ohm voice coil then when wired in paralel it would have a 2 ohm load
this in turn would mean that the amp would be outputting around 1000Wrms and that would equal some serious sound in a car as little as mine
dunno yet but if i'm able to sell my sub and amp as a combo 4 around 450 (pioneer GM-5000T amp(around 400wrms) and Pioneer TS-W38C(15inch)) then get a pretty good tax return (around 750) then i may be have some serious gear comming my way lol
my rant lol
Nate
