TimothyB
Jul 30 2006, 11:58 AM
I've got a set of 18's on my VP Commodore with 235/40 tyres and was wondering what would be the ideal amount of pressure to use for the tyres. A mate of mine said I should use 36-38psi and the place I got the mags from said I should use 38-40psi, so I've been using 38psi all along. I do about 200-250km a week of highway driving and around up to 100km of city driving. Is 38psi enough? or is it too much/not enough?
mooingchicken
Jul 30 2006, 12:49 PM
standard car tires recommend lower pressure to make a more smooth ride.
i put 38psi into my mag's which as 17" 235's. i prob wouldnt go much lower then that. and max i would put would be like 42.
master_luke
Jul 30 2006, 09:23 PM
higher the pressure means less rolling resistance, means you save more on fuel, and likely to have to have less tyre wear. At the expense of a harsher ride.
I run my Stock 13" on my pulsar at 2-4 PSI above Nissans recommended pressures
mad_bison
Jul 31 2006, 12:06 AM
for 18's daily driving i'd suggest 34psi COLD!
ie, fill the tyres up after little to no driving. (air expands as heated...it'll end up being 36-38psi anyway)
you're running 18's anyway, so ride quality is a lot less than what it's designed to be. a little bit more is not that much difference in my opinion.
for 18's on track days 38psi cold.
and for 18's on drag days 22-25psi cold.
Jul 31 2006, 12:29 AM
too high a pressure can also reduce your contact patch, and hugely extend your braking distance
RaBBiT!
Jul 31 2006, 02:10 AM
my manual says to put 24psi for my 13" thats seems a bit low to me
TimothyB
Jul 31 2006, 06:44 PM
I had new front tyres just put on and I checked the pressure and they were 40psi, so I took it on the highway to see it how handled and yeah, the steering wheel vibrated more then usual lol. I think I'll try 40psi for a while to see how slower the outer edge on the tyres wear down.
mad_bison
Jul 31 2006, 07:58 PM
i'd really only run 40psi if you were on a track mate.
i wouldn't recommend it for daily driving.
TimothyB
Jul 31 2006, 08:59 PM
Ok I'll go back to 38psi, alot more people recommend it. The vibrations from 40psi kinda gets annoying after a while lol.
