I make sub boxes and fibreglass enclosures for a living, but there's a little something I would like to share. I learnt this at uni (Thanks Peter, UNSW IDES workshop manager).
If you have come to the stage where you've done your fleece and resined the thingo, you'll end up with a very rough surface. I remember somewhere I saw you can thin bog with resin, but here's my version. Scoop out enough bog (without hardener!!!) and place in a container. Add approximately 15-20% v/v of methylated spirits and stir hard. You should end up with a thinned out bog stuff. If you end up having what looks like puke
The reason why you don't add hardener first is so that it doesn't start to cure while you're mixing in the metho. This method proved invaluable to me and is easier to sand than pure bog - must be because of the metho. Hope this helps everyone. Also the shrinkage of this mixture is more than pure bog, so don't try filling up a hole with this stuff.
