Full Version: Box For Alpine Type-R 10" Sub
n_a_t_h_a_n
I just bought two 10" ALpine type-r subwoofers. I looked up the enclosure guide from Alpine and for a sealed enclosure it says the box should be 18L for each sub. Isn't that way too small?? It says the resonate frequency will be 49Hz. Does that man the lowest sound the sub will make is 49 Hz???
Any help will be appreciated.
SPL_Lancer
Try downloading a programe called winISD. Type your sub specs into that and it whould help you make a nice box. Also the type r's go well in ported enclosures as well
n_a_t_h_a_n
I tried that and it told me 113 L. I dunno if thats right. Anyone got any other ideas??
ummmm winISD......
SPL_Lancer
Post up the specs and ill have a look.
n_a_t_h_a_n
QUOTE (SPL_Lancer @ Aug 16 2006, 06:44 PM) *
Power Handling (Peak): 1500W
Power Handling (RMS): 500W
Frequency Response: 28Hz - 500Hz
Nominal Impedance: 4Ohm+4Ohm
Sensitivity (SPL@1W/1m): 83dB
Installation Diameter: 231mm
Depth: 172mm
ok, now the T/S specs.
things like Fs, Qts Vas etc etc
n_a_t_h_a_n
QUOTE (trism @ Aug 16 2006, 07:54 PM) *
Qms/Qes/Qts: 8.76/0.43/0.41
Vas: 29L
Fs: 30Hz
Inductance (Le) 1kHz/20kHz: 3.92/1.39
Sensitivity: 85dB
DC Coil Resis. (Re): 3.6 + 3.6
Do you need anyhting else??
Sorry I dunno jack bout this technical stuff.
SPL_Lancer
30L tuned to 33Hz looks good.
n_a_t_h_a_n
QUOTE (SPL_Lancer @ Aug 16 2006, 08:27 PM) *
thanks.
QUOTE (n_a_t_h_a_n @ Aug 16 2006, 05:53 PM) *
from modelling the specs as well, 18L for a sealed enclosure per sub looks fine. not too small. smile.gif
these subs suit sealed or ported. depends what you're after:
*sealed: easier to build, smaller and lighter box; more accurate sound (less lagginess), won't play as low or loud
*ported: more complex design, bigger and heavier box; more group delay (lag), much louder and lower
