QUOTE (Liquidity @ Aug 26 2006, 10:34 PM)
accuracy depends on a number of factors. Tyre wear, external rotating diameter, correct installation and setup.
Unit should be fine, but it only goes up to 160
With the accuracy, Does it have its own speed detector, or does it hook up to existing speedo? If anything, ill also get the speed corrector from jaycar coz my current speedo is 10km faster than actual speed.
QUOTE (Nav2k @ Aug 27 2006, 08:01 AM)
u can get defi' heads up displays for just around $300 new i think...but ive seen them go for 150 2nd hand often. they're called vsd's i think.
digital, right infront of u. can also display rpm and things i think. very accurate tho. also monitors gauges if u have defi electrical gauges on heads up display
http://www.nippon-seiki.co.jp/defishop/pro.../basis_top.html The only reason im considering is coz its only $65. Plus ive always wanted a digital speedo like in the new cars. But thanx for the info.
