Model
3510d
3512d
3515d
Woofer Diameter
10"
12"
15"
Free Air Resonance
33 Hz
32 Hz
30 Hz
Qts
0.35
0.36
0.38
Qes
0.38
0.39
0.41
Qms
4.33
4.81
5.05
Vas
18 L
40 L
112 L
Straight from DD site.
As im glassing up about %70 of my boot im not sure on exact volume yet, should be about 5/6cubes.
If someone could plot it for 5 & 6 cubes tuned to 25hz & 50hz.
I plan on slot porting but obviously need exact vol to work it out. I want to be able to swap from music port to comp port tuned about around 50hz.
I read it is baad to tune below woofers Fs, Is this true & why?
I dont really care for massive 40-60hz where as I really do care about the bottom end. Subsonic will be set at 20hz. Amp is caliber Ca2000+ @ .5ohm.
Keen on any suggestions on volume / tuning freq as this is just my starting point.
I appreciate your time.
Brett.
Edit: Cant get those massive spaces out, meh.
